glTF extension to specify textures using the WebP image format. More...
#include <CesiumGltf/ExtensionTextureWebp.h>
| int32_t | source = -1 |
| The index of the WebP image. | |
| static constexpr const char * | TypeName = "ExtensionTextureWebp" |
| static constexpr const char * | ExtensionName = "EXT_texture_webp" |
Definition at line 14 of file ExtensionTextureWebp.h.
Definition at line 35 of file ExtensionTextureWebp.h.
Definition at line 22 of file ExtensionTextureWebp.h.
| int32_t CesiumGltf::ExtensionTextureWebp::source = -1 |
Definition at line 27 of file ExtensionTextureWebp.h.
Definition at line 19 of file ExtensionTextureWebp.h.
