Node-level 3DTILES_tileset extension. More...
#include <CesiumGltf/ExtensionNode3dTilesTileset.h>
Classes | |
| struct | Refine |
| Known values for Refinement determines the process by which a lower resolution parent tile renders when its higher resolution children are selected. More... | |
| double | geometricError = double() |
| A nonnegative number that defines the error, in meters, introduced if this tile is rendered and its children are not. | |
| std::optional< std::string > | refine |
| Refinement determines the process by which a lower resolution parent tile renders when its higher resolution children are selected. | |
| std::optional< CesiumGltf::Content > | content |
An object that provides additional information about the tile's content. If the tile does not have content (i.e. the node's externalAsset property is not defined) then content MUST be omitted. | |
| static constexpr const char * | TypeName = "ExtensionNode3dTilesTileset" |
| static constexpr const char * | ExtensionName = "3DTILES_tileset" |
Definition at line 16 of file ExtensionNode3dTilesTileset.h.
Definition at line 79 of file ExtensionNode3dTilesTileset.h.
| std::optional<CesiumGltf::Content> CesiumGltf::ExtensionNode3dTilesTileset::content |
Definition at line 71 of file ExtensionNode3dTilesTileset.h.
Definition at line 24 of file ExtensionNode3dTilesTileset.h.
| double CesiumGltf::ExtensionNode3dTilesTileset::geometricError = double() |
The tile geometric error. A nonnegative number that defines the error, in meters, introduced if this tile is rendered and its children are not. At runtime, the geometric error is used to compute Screen-Space Error (SSE), the error measured in pixels. The SSE determines if a tile is sufficiently detailed for the current view or if its children should be considered.
Definition at line 49 of file ExtensionNode3dTilesTileset.h.
| std::optional<std::string> CesiumGltf::ExtensionNode3dTilesTileset::refine |
Known values are defined in Refine.
Specifies the refinement type. A string that is either "REPLACE" for replacement refinement or "ADD" for additive refinement. It is required for the root tile of a tileset; it is optional for all other tiles. A tileset can use any combination of additive and replacement refinement. When the refine property is omitted, it is inherited from the parent tile.
Definition at line 64 of file ExtensionNode3dTilesTileset.h.
Definition at line 21 of file ExtensionNode3dTilesTileset.h.
