glTF extension that assigns a node to a layer. More...
#include <CesiumGltf/ExtensionNode3dTilesLayers.h>
| int32_t | layer = -1 |
The index of the layer that this node belongs to. The value is an index into the array of layers that is defined in the document-level 3DTILES_layers extension. If there is no document-level 3DTILES_layers extension and this asset is referenced by an external asset, it uses the layers of the referencing asset, recursively, until layers is found. | |
| static constexpr const char * | TypeName = "ExtensionNode3dTilesLayers" |
| static constexpr const char * | ExtensionName = "3DTILES_layers" |
Definition at line 14 of file ExtensionNode3dTilesLayers.h.
Definition at line 39 of file ExtensionNode3dTilesLayers.h.
Definition at line 22 of file ExtensionNode3dTilesLayers.h.
| int32_t CesiumGltf::ExtensionNode3dTilesLayers::layer = -1 |
Definition at line 31 of file ExtensionNode3dTilesLayers.h.
Definition at line 19 of file ExtensionNode3dTilesLayers.h.
