glTF-level 3DTILES_tileset extension. More...
#include <CesiumGltf/ExtensionModel3dTilesTileset.h>
| double | geometricError = double() |
| A nonnegative number that defines the error, in meters, that determines if the tileset is rendered. | |
| static constexpr const char * | TypeName = "ExtensionModel3dTilesTileset" |
| static constexpr const char * | ExtensionName = "3DTILES_tileset" |
Definition at line 12 of file ExtensionModel3dTilesTileset.h.
Definition at line 41 of file ExtensionModel3dTilesTileset.h.
Definition at line 20 of file ExtensionModel3dTilesTileset.h.
| double CesiumGltf::ExtensionModel3dTilesTileset::geometricError = double() |
The tileset geometric error. A nonnegative number that defines the error, in meters, that determines if the tileset is rendered. At runtime, the geometric error is used to compute Screen-Space Error (SSE), the error measured in pixels. If the SSE does not exceed a required minimum, the tileset should not be rendered, and none of its tiles should be considered for rendering.
Definition at line 33 of file ExtensionModel3dTilesTileset.h.
Definition at line 17 of file ExtensionModel3dTilesTileset.h.
