CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle Struct Referencefinal
glTF extension that specifies line width and a GPU-friendly dash pattern for CAD-style visualization. More...
#include <CesiumGltf/ExtensionMaterialBentleyMaterialsLineStyle.h>
Inheritance diagram for CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle:
int64_t width = 1
 Width of the line in screen pixels.
int64_t pattern = 65535
 Unsigned integer bitfield encoding a repeating on/off pattern along the line.
static constexpr const char * ExtensionName = "BENTLEY_materials_line_style"
Definition at line 15 of file ExtensionMaterialBentleyMaterialsLineStyle.h.
int64_t CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle::getSizeBytes ( ) const
Definition at line 56 of file ExtensionMaterialBentleyMaterialsLineStyle.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle::ExtensionName = "BENTLEY_materials_line_style"
Definition at line 24 of file ExtensionMaterialBentleyMaterialsLineStyle.h.
◆ pattern
int64_t CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle::pattern = 65535
An unsigned integer whose bits encode a repeating on/off pattern along the line. Bit value 1 indicates a lit (on) segment, and bit value 0 indicates an unlit (off) segment. The least significant bit (bit 0) corresponds to the start of the pattern and represents the first segment drawn along the line. The bit pattern repeats cyclically once all supported bits have been consumed. If a pattern uses fewer bits than the maximum supported width, unused higher bits MUST be set to zero. For example, a value of 0xFFFF produces a solid line, and a value of 0xAAAA produces a dotted line.
Definition at line 48 of file ExtensionMaterialBentleyMaterialsLineStyle.h.
const char* CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle::TypeName
Initial value:
"ExtensionMaterialBentleyMaterialsLineStyle"
Definition at line 20 of file ExtensionMaterialBentleyMaterialsLineStyle.h.
◆ width
int64_t CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle::width = 1
The thickness of the line in screen pixels. Must be greater than 0. Implementations typically render wide lines via tessellated geometry extruded from the line centerline.
Definition at line 33 of file ExtensionMaterialBentleyMaterialsLineStyle.h.
