CesiumGltf::ExtensionKhrTextureBasisu Struct Referencefinal
glTF extension to specify textures using the KTX v2 images with Basis Universal supercompression. More...
#include <CesiumGltf/ExtensionKhrTextureBasisu.h>
Inheritance diagram for CesiumGltf::ExtensionKhrTextureBasisu:
int32_t source = -1
 The index of the image which points to a KTX v2 resource with Basis Universal supercompression.
static constexpr const char * TypeName = "ExtensionKhrTextureBasisu"
static constexpr const char * ExtensionName = "KHR_texture_basisu"
Definition at line 15 of file ExtensionKhrTextureBasisu.h.
int64_t CesiumGltf::ExtensionKhrTextureBasisu::getSizeBytes ( ) const
Definition at line 37 of file ExtensionKhrTextureBasisu.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionKhrTextureBasisu::ExtensionName = "KHR_texture_basisu"
Definition at line 23 of file ExtensionKhrTextureBasisu.h.
◆ source
int32_t CesiumGltf::ExtensionKhrTextureBasisu::source = -1
Definition at line 29 of file ExtensionKhrTextureBasisu.h.
const char* CesiumGltf::ExtensionKhrTextureBasisu::TypeName = "ExtensionKhrTextureBasisu"
Definition at line 20 of file ExtensionKhrTextureBasisu.h.
