CesiumGltf::ExtensionKhrMaterialsUnlit Struct Referencefinal
glTF extension that defines the unlit material model. More...
#include <CesiumGltf/ExtensionKhrMaterialsUnlit.h>
Inheritance diagram for CesiumGltf::ExtensionKhrMaterialsUnlit:
static constexpr const char * TypeName = "ExtensionKhrMaterialsUnlit"
static constexpr const char * ExtensionName = "KHR_materials_unlit"
Additional Inherited Members
Definition at line 12 of file ExtensionKhrMaterialsUnlit.h.
int64_t CesiumGltf::ExtensionKhrMaterialsUnlit::getSizeBytes ( ) const
Definition at line 28 of file ExtensionKhrMaterialsUnlit.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionKhrMaterialsUnlit::ExtensionName = "KHR_materials_unlit"
Definition at line 20 of file ExtensionKhrMaterialsUnlit.h.
const char* CesiumGltf::ExtensionKhrMaterialsUnlit::TypeName = "ExtensionKhrMaterialsUnlit"
Definition at line 17 of file ExtensionKhrMaterialsUnlit.h.
