cesium-native 0.62.0
CesiumGltf::ExtensionKhrGaussianSplattingHintsValue Struct Referencefinal
Optional rendering hints for rendering the 3D Gaussian splats. Renderers are free to ignore any of these. More...
#include <CesiumGltf/ExtensionKhrGaussianSplattingHintsValue.h>
Inheritance diagram for CesiumGltf::ExtensionKhrGaussianSplattingHintsValue:
const JsonValuegetGenericExtension (const std::string &extensionName) const noexcept
JsonValuegetGenericExtension (const std::string &extensionName) noexcept
std::string projection = "perspective"
 Provides a hint specifying how to project the Gaussians to achieve a perspective correct value. This is a freeform field that defaults to perspective. See the extension specification for further known types.
std::string sortingMethod = "cameraDistance"
 Provides a hint specifying how to sort the Gaussians during rendering. This is a freeform field defaulting to cameraDistance. See the extension specification for further known types.
Definition at line 15 of file ExtensionKhrGaussianSplattingHintsValue.h.
int64_t CesiumGltf::ExtensionKhrGaussianSplattingHintsValue::getSizeBytes ( ) const
Definition at line 43 of file ExtensionKhrGaussianSplattingHintsValue.h.
◆ projection
std::string CesiumGltf::ExtensionKhrGaussianSplattingHintsValue::projection = "perspective"
Definition at line 28 of file ExtensionKhrGaussianSplattingHintsValue.h.
◆ sortingMethod
std::string CesiumGltf::ExtensionKhrGaussianSplattingHintsValue::sortingMethod = "cameraDistance"
Definition at line 35 of file ExtensionKhrGaussianSplattingHintsValue.h.
const char* CesiumGltf::ExtensionKhrGaussianSplattingHintsValue::TypeName
Initial value:
"ExtensionKhrGaussianSplattingHintsValue"
Definition at line 20 of file ExtensionKhrGaussianSplattingHintsValue.h.
