CesiumGltf::ExtensionExtStructuralMetadata Struct Referencefinal
Structural metadata about a glTF element. More...
#include <CesiumGltf/ExtensionExtStructuralMetadata.h>
Inheritance diagram for CesiumGltf::ExtensionExtStructuralMetadata:
std::optional< std::string > classProperty
 The class that property values conform to. The value shall be a class ID declared in the classes dictionary of the metadata schema.
std::unordered_map< std::string, CesiumUtility::JsonValue > properties
 A dictionary, where each key corresponds to a property ID in the class' properties dictionary and each value contains the property values. The type of the value shall match the property definition: For BOOLEAN use true or false. For STRING use a JSON string. For numeric types use a JSON number. For ENUM use a valid enum name, not an integer value. For ARRAY, VECN, and MATN types use a JSON array containing values matching the componentType. Required properties shall be included in this dictionary.
static constexpr const char * TypeName = "ExtensionExtStructuralMetadata"
static constexpr const char * ExtensionName = "EXT_structural_metadata"
Definition at line 17 of file ExtensionExtStructuralMetadata.h.
int64_t CesiumGltf::ExtensionExtStructuralMetadata::getSizeBytes ( ) const
Definition at line 51 of file ExtensionExtStructuralMetadata.h.
◆ classProperty
std::optional<std::string> CesiumGltf::ExtensionExtStructuralMetadata::classProperty
Definition at line 31 of file ExtensionExtStructuralMetadata.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtStructuralMetadata::ExtensionName = "EXT_structural_metadata"
Definition at line 25 of file ExtensionExtStructuralMetadata.h.
◆ properties
std::unordered_map<std::string, CesiumUtility::JsonValue> CesiumGltf::ExtensionExtStructuralMetadata::properties
Definition at line 43 of file ExtensionExtStructuralMetadata.h.
const char* CesiumGltf::ExtensionExtStructuralMetadata::TypeName = "ExtensionExtStructuralMetadata"
Definition at line 22 of file ExtensionExtStructuralMetadata.h.
