CesiumGltf::ExtensionExtMeshPolygon Struct Referencefinal
glTF extension adding an encoding of polygon primitive topology More...
#include <CesiumGltf/ExtensionExtMeshPolygon.h>
Inheritance diagram for CesiumGltf::ExtensionExtMeshPolygon:
int32_t count = -1
 Integer number of polygons encoded in the mesh primitive.
int32_t loopIndices = -1
 Index of an accessor containing indices of the polygons' exterior and interior loops. The accessor MUST have SCALAR type and an unsigned integer component type.
int32_t loopIndicesOffsets = -1
 Index of an accessor containing one integer offset per polygon in the primitive, indicating the first index of the first linear ring associated with that polygon.
int32_t indicesOffsets = -1
 Index of an accessor containing one integer offset per polygon in the primitive, indicating the first index of the first triangle associated with that polygon.
static constexpr const char * TypeName = "ExtensionExtMeshPolygon"
static constexpr const char * ExtensionName = "EXT_mesh_polygon"
Definition at line 14 of file ExtensionExtMeshPolygon.h.
int64_t CesiumGltf::ExtensionExtMeshPolygon::getSizeBytes ( ) const
Definition at line 56 of file ExtensionExtMeshPolygon.h.
◆ count
int32_t CesiumGltf::ExtensionExtMeshPolygon::count = -1
Definition at line 27 of file ExtensionExtMeshPolygon.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtMeshPolygon::ExtensionName = "EXT_mesh_polygon"
Definition at line 22 of file ExtensionExtMeshPolygon.h.
◆ indicesOffsets
int32_t CesiumGltf::ExtensionExtMeshPolygon::indicesOffsets = -1
Definition at line 48 of file ExtensionExtMeshPolygon.h.
◆ loopIndices
int32_t CesiumGltf::ExtensionExtMeshPolygon::loopIndices = -1
Definition at line 34 of file ExtensionExtMeshPolygon.h.
◆ loopIndicesOffsets
int32_t CesiumGltf::ExtensionExtMeshPolygon::loopIndicesOffsets = -1
Definition at line 41 of file ExtensionExtMeshPolygon.h.
const char* CesiumGltf::ExtensionExtMeshPolygon::TypeName = "ExtensionExtMeshPolygon"
Definition at line 19 of file ExtensionExtMeshPolygon.h.
