glTF extension defines instance attributes for a node with a mesh. More...
#include <CesiumGltf/ExtensionExtMeshGpuInstancing.h>
| std::unordered_map< std::string, int32_t > | attributes |
A dictionary object, where each key corresponds to instance attribute and each value is the index of the accessor containing attribute's data. Attributes TRANSLATION, ROTATION, SCALE define instance transformation. For "TRANSLATION" the values are FLOAT_VEC3's specifying translation along the x, y, and z axes. For "ROTATION" the values are VEC4's specifying rotation as a quaternion in the order (x, y, z, w), where w is the scalar, with component type FLOAT or normalized integer. For "SCALE" the values are FLOAT_VEC3's specifying scaling factors along the x, y, and z axes. | |
| static constexpr const char * | TypeName = "ExtensionExtMeshGpuInstancing" |
| static constexpr const char * | ExtensionName = "EXT_mesh_gpu_instancing" |
Definition at line 16 of file ExtensionExtMeshGpuInstancing.h.
Definition at line 45 of file ExtensionExtMeshGpuInstancing.h.
| std::unordered_map<std::string, int32_t> CesiumGltf::ExtensionExtMeshGpuInstancing::attributes |
Definition at line 37 of file ExtensionExtMeshGpuInstancing.h.
Definition at line 24 of file ExtensionExtMeshGpuInstancing.h.
Definition at line 21 of file ExtensionExtMeshGpuInstancing.h.
