This extension declares the Coordinate Reference System (CRS) in which a glTF 2.1 asset was authored. The CRS is provided as a Well-Known Text (version 2) string. More...
#include <CesiumGltf/ExtensionExtGeospatialCrsWkt2.h>
| std::string | wkt2 |
| The Coordinate Reference System provided as a Well-Known Text (version 2) string. | |
| static constexpr const char * | TypeName = "ExtensionExtGeospatialCrsWkt2" |
| static constexpr const char * | ExtensionName = "EXT_geospatial_crs_wkt2" |
Definition at line 16 of file ExtensionExtGeospatialCrsWkt2.h.
Definition at line 38 of file ExtensionExtGeospatialCrsWkt2.h.
Definition at line 24 of file ExtensionExtGeospatialCrsWkt2.h.
Definition at line 21 of file ExtensionExtGeospatialCrsWkt2.h.
| std::string CesiumGltf::ExtensionExtGeospatialCrsWkt2::wkt2 |
Definition at line 30 of file ExtensionExtGeospatialCrsWkt2.h.
