This extension georeferences a node to the provided geographic coordinates. More...
#include <CesiumGltf/ExtensionExtGeoreference.h>
| double | longitude = double() |
| Longitude in degrees. | |
| double | latitude = double() |
| Latitude in degrees. | |
| std::optional< double > | height |
| Height above (or below) the ellipsoid specified in meters. | |
| static constexpr const char * | TypeName = "ExtensionExtGeoreference" |
| static constexpr const char * | ExtensionName = "EXT_georeference" |
Definition at line 15 of file ExtensionExtGeoreference.h.
Definition at line 46 of file ExtensionExtGeoreference.h.
Definition at line 23 of file ExtensionExtGeoreference.h.
| std::optional<double> CesiumGltf::ExtensionExtGeoreference::height |
Definition at line 38 of file ExtensionExtGeoreference.h.
| double CesiumGltf::ExtensionExtGeoreference::latitude = double() |
Definition at line 33 of file ExtensionExtGeoreference.h.
| double CesiumGltf::ExtensionExtGeoreference::longitude = double() |
Definition at line 28 of file ExtensionExtGeoreference.h.
Definition at line 20 of file ExtensionExtGeoreference.h.
