CESIUM_tile_edges extension for a primitive in a glTF model.
More...
#include <CesiumGltf/ExtensionCesiumTileEdges.h>
| int32_t | left = -1 |
| The index of the accessor containing indices that make up the left edge. | |
| int32_t | bottom = -1 |
| The index of the accessor containing indices that make up the bottom edge. | |
| int32_t | right = -1 |
| The index of the accessor containing indices that make up the right edge. | |
| int32_t | top = -1 |
| The index of the accessor containing indices that make up the top edge. | |
| static constexpr const char * | TypeName = "ExtensionCesiumTileEdges" |
| static constexpr const char * | ExtensionName = "CESIUM_tile_edges" |
Definition at line 14 of file ExtensionCesiumTileEdges.h.
Definition at line 54 of file ExtensionCesiumTileEdges.h.
| int32_t CesiumGltf::ExtensionCesiumTileEdges::bottom = -1 |
Definition at line 34 of file ExtensionCesiumTileEdges.h.
Definition at line 22 of file ExtensionCesiumTileEdges.h.
| int32_t CesiumGltf::ExtensionCesiumTileEdges::left = -1 |
Definition at line 28 of file ExtensionCesiumTileEdges.h.
| int32_t CesiumGltf::ExtensionCesiumTileEdges::right = -1 |
Definition at line 40 of file ExtensionCesiumTileEdges.h.
| int32_t CesiumGltf::ExtensionCesiumTileEdges::top = -1 |
Definition at line 46 of file ExtensionCesiumTileEdges.h.
Definition at line 19 of file ExtensionCesiumTileEdges.h.
