cesium-native 0.67.0
glTF CESIUM_RTC extension. More...
#include <CesiumGltf/ExtensionCesiumRTC.h>
| std::vector< double > | center |
| Center that vertex positions are relative to. | |
| static constexpr const char * | TypeName = "ExtensionCesiumRTC" |
| static constexpr const char * | ExtensionName = "CESIUM_RTC" |
Definition at line 14 of file ExtensionCesiumRTC.h.
Definition at line 35 of file ExtensionCesiumRTC.h.
| std::vector<double> CesiumGltf::ExtensionCesiumRTC::center |
Definition at line 27 of file ExtensionCesiumRTC.h.
Definition at line 22 of file ExtensionCesiumRTC.h.
Definition at line 19 of file ExtensionCesiumRTC.h.
