glTF extension for indicating that some edges of a primitive's triangles should be outlined. More...
#include <CesiumGltf/ExtensionCesiumPrimitiveOutline.h>
| int32_t | indices = -1 |
| The index of the accessor providing the list of highlighted lines at the edge of this primitive's triangles. | |
| static constexpr const char * | TypeName = "ExtensionCesiumPrimitiveOutline" |
| static constexpr const char * | ExtensionName = "CESIUM_primitive_outline" |
Definition at line 15 of file ExtensionCesiumPrimitiveOutline.h.
Definition at line 37 of file ExtensionCesiumPrimitiveOutline.h.
Definition at line 23 of file ExtensionCesiumPrimitiveOutline.h.
| int32_t CesiumGltf::ExtensionCesiumPrimitiveOutline::indices = -1 |
Definition at line 29 of file ExtensionCesiumPrimitiveOutline.h.
Definition at line 20 of file ExtensionCesiumPrimitiveOutline.h.
