CesiumGltf::ExtensionBufferViewExtMeshoptCompression Struct Referencefinal
Compressed data for bufferView. More...
#include <CesiumGltf/ExtensionBufferViewExtMeshoptCompression.h>
Inheritance diagram for CesiumGltf::ExtensionBufferViewExtMeshoptCompression:
Classes
struct  Filter
 Known values for The compression filter. More...
struct  Mode
 Known values for The compression mode. More...
int32_t buffer = -1
 The index of the buffer with compressed data.
int64_t byteOffset = 0
 The offset into the buffer in bytes.
int64_t byteLength = int64_t()
 The length of the compressed data in bytes.
int64_t byteStride = int64_t()
 The stride, in bytes.
int64_t count = int64_t()
 The number of elements.
std::string mode = Mode::ATTRIBUTES
std::string filter = Filter::NONE
static constexpr const char * ExtensionName = "EXT_meshopt_compression"
Definition at line 15 of file ExtensionBufferViewExtMeshoptCompression.h.
int64_t CesiumGltf::ExtensionBufferViewExtMeshoptCompression::getSizeBytes ( ) const
Definition at line 104 of file ExtensionBufferViewExtMeshoptCompression.h.
◆ buffer
int32_t CesiumGltf::ExtensionBufferViewExtMeshoptCompression::buffer = -1
Definition at line 60 of file ExtensionBufferViewExtMeshoptCompression.h.
◆ byteLength
int64_t CesiumGltf::ExtensionBufferViewExtMeshoptCompression::byteLength = int64_t()
Definition at line 70 of file ExtensionBufferViewExtMeshoptCompression.h.
◆ byteOffset
int64_t CesiumGltf::ExtensionBufferViewExtMeshoptCompression::byteOffset = 0
Definition at line 65 of file ExtensionBufferViewExtMeshoptCompression.h.
◆ byteStride
int64_t CesiumGltf::ExtensionBufferViewExtMeshoptCompression::byteStride = int64_t()
Definition at line 75 of file ExtensionBufferViewExtMeshoptCompression.h.
◆ count
int64_t CesiumGltf::ExtensionBufferViewExtMeshoptCompression::count = int64_t()
Definition at line 80 of file ExtensionBufferViewExtMeshoptCompression.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionBufferViewExtMeshoptCompression::ExtensionName = "EXT_meshopt_compression"
Definition at line 24 of file ExtensionBufferViewExtMeshoptCompression.h.
◆ filter
std::string CesiumGltf::ExtensionBufferViewExtMeshoptCompression::filter = Filter::NONE
Known values are defined in Filter.
Definition at line 96 of file ExtensionBufferViewExtMeshoptCompression.h.
◆ mode
std::string CesiumGltf::ExtensionBufferViewExtMeshoptCompression::mode = Mode::ATTRIBUTES
Known values are defined in Mode.
Definition at line 88 of file ExtensionBufferViewExtMeshoptCompression.h.
const char* CesiumGltf::ExtensionBufferViewExtMeshoptCompression::TypeName
Initial value:
"ExtensionBufferViewExtMeshoptCompression"
Definition at line 20 of file ExtensionBufferViewExtMeshoptCompression.h.
