Specifies point diameter for CAD-style visualization. More...
#include <CesiumGltf/ExtensionBentleyMaterialsPointStyle.h>
| int64_t | diameter = int64_t() |
| Diameter of the point in screen pixels. Must be > 0. | |
| static constexpr const char * | TypeName = "ExtensionBentleyMaterialsPointStyle" |
| static constexpr const char * | ExtensionName = "BENTLEY_materials_point_style" |
Definition at line 14 of file ExtensionBentleyMaterialsPointStyle.h.
Definition at line 35 of file ExtensionBentleyMaterialsPointStyle.h.
| int64_t CesiumGltf::ExtensionBentleyMaterialsPointStyle::diameter = int64_t() |
Definition at line 27 of file ExtensionBentleyMaterialsPointStyle.h.
Definition at line 22 of file ExtensionBentleyMaterialsPointStyle.h.
Definition at line 19 of file ExtensionBentleyMaterialsPointStyle.h.
