3D Tiles vector content extension. Specifies that a tileset's tiles contains vector point, line, or polygon geometries with intrinsic semantic meaning, but without intrinsic rendering intent. More...
#include <CesiumGltf/Extension3dTilesTilesetVectors.h>
| bool | clip = false |
| Whether content should be clipped to tile bounds when rendering. | |
| static constexpr const char * | TypeName = "Extension3dTilesTilesetVectors" |
| static constexpr const char * | ExtensionName = "3DTILES_tileset_vectors" |
Definition at line 14 of file Extension3dTilesTilesetVectors.h.
Definition at line 35 of file Extension3dTilesTilesetVectors.h.
| bool CesiumGltf::Extension3dTilesTilesetVectors::clip = false |
Definition at line 27 of file Extension3dTilesTilesetVectors.h.
Definition at line 22 of file Extension3dTilesTilesetVectors.h.
Definition at line 19 of file Extension3dTilesTilesetVectors.h.
