CesiumGltf::Extension3dTilesImplicitTiling Struct Referencefinal
Implicit tiling defines a concise representation of quadtrees and octrees in 3D Tiles. More...
#include <CesiumGltf/Extension3dTilesImplicitTiling.h>
Inheritance diagram for CesiumGltf::Extension3dTilesImplicitTiling:
Classes
struct  SubdivisionScheme
 Known values for Either QUADTREE or OCTREE. See Subdivision scheme. More...
std::string contentUri
 Template URI for locating content files.
std::string subtreeUri
 Template URI for locating subtree files.
std::string subdivisionScheme = SubdivisionScheme::QUADTREE
int64_t availableLevels = int64_t()
 How many levels there are in the tree with available tiles.
int64_t subtreeLevels = int64_t()
 How many levels there are in each subtree.
static constexpr const char * TypeName = "Extension3dTilesImplicitTiling"
static constexpr const char * ExtensionName = "3DTILES_implicit_tiling"
Definition at line 16 of file Extension3dTilesImplicitTiling.h.
int64_t CesiumGltf::Extension3dTilesImplicitTiling::getSizeBytes ( ) const
Definition at line 75 of file Extension3dTilesImplicitTiling.h.
◆ availableLevels
int64_t CesiumGltf::Extension3dTilesImplicitTiling::availableLevels = int64_t()
Definition at line 62 of file Extension3dTilesImplicitTiling.h.
◆ contentUri
std::string CesiumGltf::Extension3dTilesImplicitTiling::contentUri
A template URI pointing to tile content. It contains placeholders {level}, {x}, {y}, and optionally {z} (for OCTREE subdivision scheme) that are substituted with a tile's coordinate to resolve the actual file. Example: content/{level}/{x}/{y}.glb.
Definition at line 42 of file Extension3dTilesImplicitTiling.h.
◆ ExtensionName
const char* CesiumGltf::Extension3dTilesImplicitTiling::ExtensionName = "3DTILES_implicit_tiling"
Definition at line 24 of file Extension3dTilesImplicitTiling.h.
◆ subdivisionScheme
std::string CesiumGltf::Extension3dTilesImplicitTiling::subdivisionScheme = SubdivisionScheme::QUADTREE
Known values are defined in SubdivisionScheme.
Definition at line 57 of file Extension3dTilesImplicitTiling.h.
◆ subtreeLevels
int64_t CesiumGltf::Extension3dTilesImplicitTiling::subtreeLevels = int64_t()
Definition at line 67 of file Extension3dTilesImplicitTiling.h.
◆ subtreeUri
std::string CesiumGltf::Extension3dTilesImplicitTiling::subtreeUri
A template URI pointing to subtree files. It contains placeholders {level}, {x}, {y}, and optionally {z} (for OCTREE subdivision scheme) that are substituted with a subtree's coordinate to resolve the actual file. Example: subtrees/{level}/{x}/{y}.json.
Definition at line 49 of file Extension3dTilesImplicitTiling.h.
const char* CesiumGltf::Extension3dTilesImplicitTiling::TypeName = "Extension3dTilesImplicitTiling"
Definition at line 21 of file Extension3dTilesImplicitTiling.h.
