CesiumGltf::Extension3dTilesHorizonOcclusionPoint Struct Referencefinal
3DTILES_horizon_occlusion_point More...
#include <CesiumGltf/Extension3dTilesHorizonOcclusionPoint.h>
Inheritance diagram for CesiumGltf::Extension3dTilesHorizonOcclusionPoint:
std::vector< double > horizonOcclusionPoint
 The horizon occlusion point expressed in an ellipsoid-scaled fixed frame. If this point is below the horizon, the entire tile is below the horizon.
static constexpr const char * ExtensionName
Definition at line 14 of file Extension3dTilesHorizonOcclusionPoint.h.
int64_t CesiumGltf::Extension3dTilesHorizonOcclusionPoint::getSizeBytes ( ) const
Definition at line 39 of file Extension3dTilesHorizonOcclusionPoint.h.
◆ ExtensionName
const char* CesiumGltf::Extension3dTilesHorizonOcclusionPoint::ExtensionName
Initial value:
"3DTILES_horizon_occlusion_point"
Definition at line 23 of file Extension3dTilesHorizonOcclusionPoint.h.
◆ horizonOcclusionPoint
std::vector<double> CesiumGltf::Extension3dTilesHorizonOcclusionPoint::horizonOcclusionPoint
Definition at line 31 of file Extension3dTilesHorizonOcclusionPoint.h.
const char* CesiumGltf::Extension3dTilesHorizonOcclusionPoint::TypeName
Initial value:
"Extension3dTilesHorizonOcclusionPoint"
Definition at line 19 of file Extension3dTilesHorizonOcclusionPoint.h.
