cesium-native 0.61.0
Enables loading GeoJSON content in 3D Tiles. This extension is declared at the tileset level to enable the use of GeoJSON content and optional properties metadata schemas in metadata entities. More...
#include <Cesium3DTiles/ExtensionMaxarContentGeoJson.h>
Gets a generic extension with the given name as a CesiumUtility::JsonValue. | |
| static constexpr const char * | TypeName = "ExtensionMaxarContentGeoJson" |
| static constexpr const char * | ExtensionName = "MAXAR_content_geojson" |
Definition at line 14 of file ExtensionMaxarContentGeoJson.h.
Definition at line 30 of file ExtensionMaxarContentGeoJson.h.
Definition at line 22 of file ExtensionMaxarContentGeoJson.h.
Definition at line 19 of file ExtensionMaxarContentGeoJson.h.
