CesiumUtility::DerivedValue< TInput, TDerivation > Class Template Reference
A function object that caches the last result of a derivation function based on its input. This is sometimes called "memoization", but this simple implementation only remembers the result of a single past invocation. More...
#include <CesiumUtility/DerivedValue.h>
Public Types
using TOutput = std::invoke_result_t<TDerivation, TInput>
 The type returned by the derivation function.
 DerivedValue (const TDerivation &derivation)
 Constructs a new instance that will use the given derivation function.
 DerivedValue (TDerivation &&derivation)
TOutput operator() (T &&input)
 Gets or computes the derived value.
template<typename TInput, typename TDerivation>
class CesiumUtility::DerivedValue< TInput, TDerivation >
Please note that this class is not thread-safe.
Template Parameters
TInputThe type of parameter passed as input to the derivation function. It must be possible (and, preferably, efficient) to compare instances of this type using operator!=.
TDerivationThe type of the derivation function. This must be a callable type that takes a single parameter of type TInput and returns a non-void value.
Definition at line 26 of file DerivedValue.h.
Member Typedef Documentation
◆ TOutput
using CesiumUtility::DerivedValue< TInput, TDerivation >::TOutput = std::invoke_result_t<TDerivation, TInput>
Definition at line 31 of file DerivedValue.h.
◆ DerivedValue() [1/2]
CesiumUtility::DerivedValue< TInput, TDerivation >::DerivedValue ( const TDerivation & derivation)
Definition at line 37 of file DerivedValue.h.
◆ DerivedValue() [2/2]
CesiumUtility::DerivedValue< TInput, TDerivation >::DerivedValue ( TDerivation && derivation)
Definition at line 44 of file DerivedValue.h.
◆ operator()()
TOutput CesiumUtility::DerivedValue< TInput, TDerivation >::operator() ( T && input)
If this is the first time this method was invoked, or if the given input is different from the last time this method was invoked (as indicated by operator!=), the derivation function will be called to compute the derived value. The derived value will be cached and returned.
Otherwise, the previously-computed value will be returned.
Definition at line 57 of file DerivedValue.h.
