JsonWriter.h
3#include <rapidjson/stringbuffer.h>
4#include <rapidjson/writer.h>
5
6#include <cstddef>
7#include <cstdint>
8#include <functional>
9#include <memory>
10#include <string>
11#include <string_view>
12#include <vector>
13
14namespace CesiumJsonWriter {
18class JsonWriter {
19public:
20 JsonWriter();
21 virtual ~JsonWriter() = default;
22
27 virtual bool Null();
33 virtual bool Bool(bool b);
39 virtual bool Int(int i);
45 virtual bool Uint(unsigned int i);
51 virtual bool Uint64(std::uint64_t i);
57 virtual bool Int64(std::int64_t i);
63 virtual bool Double(double d);
73 virtual bool RawNumber(const char* str, unsigned int length, bool copy);
80 virtual bool Key(std::string_view string);
87 virtual bool String(std::string_view string);
93 virtual bool StartObject();
99 virtual bool EndObject();
105 virtual bool StartArray();
111 virtual bool EndArray();
112
118 virtual void Primitive(std::int32_t value);
124 virtual void Primitive(std::uint32_t value);
130 virtual void Primitive(std::int64_t value);
136 virtual void Primitive(std::uint64_t value);
142 virtual void Primitive(float value);
148 virtual void Primitive(double value);
154 virtual void Primitive(std::nullptr_t value);
160 virtual void Primitive(std::string_view string);
161
169 virtual void KeyPrimitive(std::string_view keyName, std::int32_t value);
177 virtual void KeyPrimitive(std::string_view keyName, std::uint32_t value);
185 virtual void KeyPrimitive(std::string_view keyName, std::int64_t value);
193 virtual void KeyPrimitive(std::string_view keyName, std::uint64_t value);
201 virtual void KeyPrimitive(std::string_view keyName, std::string_view value);
209 virtual void KeyPrimitive(std::string_view keyName, float value);
217 virtual void KeyPrimitive(std::string_view keyName, double value);
225 virtual void KeyPrimitive(std::string_view keyName, std::nullptr_t value);
226
237 virtual void KeyArray(
238 std::string_view keyName,
239 const std::function<void(void)>& insideArray);
250 virtual void KeyObject(
251 std::string_view keyName,
252 const std::function<void(void)>& insideObject);
253
257 virtual std::string toString();
261 virtual std::string_view toStringView();
265 virtual std::vector<std::byte> toBytes();
266
270 template <typename ErrorStr> void emplaceError(ErrorStr&& error) {
271 _errors.emplace_back(std::forward<ErrorStr>(error));
272 }
273
277 template <typename WarningStr> void emplaceWarning(WarningStr&& warning) {
278 _warnings.emplace_back(std::forward<WarningStr>(warning));
279 }
280
284 const std::vector<std::string>& getErrors() const { return _errors; }
288 const std::vector<std::string>& getWarnings() const { return _warnings; }
289
290private:
291 rapidjson::StringBuffer _compactBuffer;
292 std::unique_ptr<rapidjson::Writer<rapidjson::StringBuffer>> _compact;
293
294 std::vector<std::string> _errors;
295 std::vector<std::string> _warnings;
296};
297} // namespace CesiumJsonWriter
Writes the given key and its corresponding value primitive to the output. This is a convenience funct...
Writes a signed integer value to the output.
Writes the given primitive to the output. This is a convenience function for Uint.
void emplaceWarning(WarningStr &&warning)
Emplaces a new warning into the internal warning buffer.
Definition JsonWriter.h:277
const std::vector< std::string > & getErrors() const
Obtains the current error buffer.
Definition JsonWriter.h:284
Writes the start of a JSON object to the output.
Writes the given primitive to the output. This is a convenience function for Int.
Writes the given primitive to the output. This is a convenience function for Null.
Writes a 64-bit floating point value to the output.
Writes the given primitive to the output. This is a convenience function for Double.
virtual void KeyObject(std::string_view keyName, const std::function< void(void)> &insideObject)
Writes an object to the output with the given key and calls the provided callback to write values ins...
Writes the end of a JSON object to the output.
Writes a boolean value to the output.
virtual void KeyArray(std::string_view keyName, const std::function< void(void)> &insideArray)
Writes an array to the output with the given key and calls the provided callback to write values insi...
void emplaceError(ErrorStr &&error)
Emplaces a new error into the internal error buffer.
Definition JsonWriter.h:270
virtual bool RawNumber(const char *str, unsigned int length, bool copy)
Writes the given string as a number to the output without any kind of special handling.
Obtains the written output as a string.
Writes the given string as an object key to the output.
Writes an unsigned 64-bit integer value to the output.
Writes the given primitive to the output. This is a convenience function for Int64.
Writes the given primitive to the output. This is a convenience function for String.
Writes the end of a JSON array to the output.
Writes the given primitive to the output. This is a convenience function for Uint64.
virtual bool Null()
Writes a null value to the output.
Writes the given string as a value to the output.
Obtains the written output as a string_view.
const std::vector< std::string > & getWarnings() const
Obtains the current warning buffer.
Definition JsonWriter.h:288
Writes an unsigned integer value to the output.
virtual std::vector< std::byte > toBytes()
Obtains the written output as a buffer of bytes.
Writes an signed 64-bit integer value to the output.
Writes the start of a JSON array to the output.
Classes for writing JSON.
