A utility class that parses KHR_texture_transform parameters and transforms input texture coordinates. More...
#include <CesiumGltf/KhrTextureTransform.h>
| KhrTextureTransform () noexcept | |
| Constructs a texture transformation with identity values. | |
| KhrTextureTransform (const ExtensionKhrTextureTransform &extension) noexcept | |
| Constructs a texture transformation from the given extension. | |
| KhrTextureTransformStatus | status () const noexcept |
| The current KhrTextureTransformStatus of the transform operation. | |
| glm::dvec2 | offset () const noexcept |
| Gets the offset of the texture transform. | |
| double | rotation () const noexcept |
| Gets the rotation (in radians) of the texture transform. | |
| glm::dvec2 | rotationSineCosine () const noexcept |
| Gets the sine and cosine of the rotation in the texture transform. This is cached to avoid re-computing the values in the future. | |
| glm::dvec2 | scale () const noexcept |
| Gets the scale of the texture transform. | |
| glm::dvec2 | applyTransform (double u, double v) const noexcept |
| Applies this texture transformation to the input coordinates. | |
| std::optional< int64_t > | getTexCoordSetIndex () const noexcept |
| Gets the texture coordinate set index used by this texture transform. If defined, this should override the set index of the texture's original textureInfo. | |
Definition at line 25 of file KhrTextureTransform.h.
inlinenoexcept |
Definition at line 76 of file KhrTextureTransform.h.
inlinenoexcept |
Definition at line 46 of file KhrTextureTransform.h.
inlinenoexcept |
Definition at line 51 of file KhrTextureTransform.h.
inlinenoexcept |
Definition at line 57 of file KhrTextureTransform.h.
inlinenoexcept |
Definition at line 64 of file KhrTextureTransform.h.
inlinenoexcept |
Definition at line 41 of file KhrTextureTransform.h.
