TilesetWriter.h
3#include <CesiumJsonWriter/ExtensionWriterContext.h>
4#include <CesiumTilesetJsonWriter/Library.h>
5
6// forward declarations
7namespace CesiumTilesetJson {
8struct Tileset;
9}
10
12
17struct CESIUMTILESETJSONWRITER_API TilesetWriterResult {
21 std::vector<std::byte> tilesetBytes;
22
26 std::vector<std::string> errors;
27
31 std::vector<std::string> warnings;
32};
33
37struct CESIUMTILESETJSONWRITER_API TilesetWriterOptions {
41 bool prettyPrint = false;
42};
43
79
80} // namespace CesiumTilesetJsonWriter
TilesetWriter()
const CesiumJsonWriter::ExtensionWriterContext & getExtensions() const
Gets the context used to control how tileset extensions are written.
TilesetWriterResult writeTileset(const CesiumTilesetJson::Tileset &tileset, const TilesetWriterOptions &options=TilesetWriterOptions()) const
Serializes the provided tileset object into a byte vector using the provided flags to convert.
Classes for writing a tileset.json from 3D Tiles 1.1.
Options for how to write a tileset.
bool prettyPrint
If the tileset JSON should be pretty printed.
The result of writing a tileset with TilesetWriter::writeTileset.
std::vector< std::byte > tilesetBytes
The final generated std::vector<std::byte> of the tileset.
This class is not meant to be instantiated directly. Use Tileset instead.
Definition Tileset.h:13
