MaterialPBRMetallicRoughnessReader.h
5#include <CesiumGltf/MaterialPBRMetallicRoughness.h>
9
10#include <rapidjson/fwd.h>
11
12#include <span>
13#include <vector>
14
15namespace CesiumGltf {
17} // namespace CesiumGltf
18
20
25class CESIUMGLTFREADER_API MaterialPBRMetallicRoughnessReader {
26public:
31
36
41
50 readFromJson(const std::span<const std::byte>& data) const;
51
60 readFromJson(const rapidjson::Value& value) const;
61
70 std::vector<CesiumGltf::MaterialPBRMetallicRoughness>>
71 readArrayFromJson(const rapidjson::Value& value) const;
72
73private:
75};
76
77} // namespace CesiumGltfReader
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::MaterialPBRMetallicRoughness > > readArrayFromJson(const rapidjson::Value &value) const
Reads an array of instances of MaterialPBRMetallicRoughness from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< CesiumGltf::MaterialPBRMetallicRoughness > readFromJson(const std::span< const std::byte > &data) const
Reads an instance of MaterialPBRMetallicRoughness from a byte buffer.
MaterialPBRMetallicRoughnessReader()
CesiumJsonReader::ReadJsonResult< CesiumGltf::MaterialPBRMetallicRoughness > readFromJson(const rapidjson::Value &value) const
Reads an instance of MaterialPBRMetallicRoughness from a rapidJson::Value.
Definition GltfReader.h:23
A set of parameter values that are used to define the metallic-roughness material model from Physical...
Definition JsonReader.h:23
