ExtensionModelExtNodeVisibilityConditionsReader.h
5#include <CesiumGltf/ExtensionModelExtNodeVisibilityConditions.h>
9
10#include <rapidjson/fwd.h>
11
12#include <span>
13#include <vector>
14
15namespace CesiumGltf {
17} // namespace CesiumGltf
18
20
26public:
31
36
41
51 readFromJson(const std::span<const std::byte>& data) const;
52
62 readFromJson(const rapidjson::Value& value) const;
63
72 std::vector<CesiumGltf::ExtensionModelExtNodeVisibilityConditions>>
73 readArrayFromJson(const rapidjson::Value& value) const;
74
75private:
77};
78
79} // namespace CesiumGltfReader
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtNodeVisibilityConditions > readFromJson(const std::span< const std::byte > &data) const
Reads an instance of ExtensionModelExtNodeVisibilityConditions from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtNodeVisibilityConditions > readFromJson(const rapidjson::Value &value) const
Reads an instance of ExtensionModelExtNodeVisibilityConditions from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionModelExtNodeVisibilityConditions > > readArrayFromJson(const rapidjson::Value &value) const
Reads an array of instances of ExtensionModelExtNodeVisibilityConditions from a rapidJson::Value.
Definition GltfReader.h:23
Defines the structure of the extension object that is stored as the EXT_node_visibility_conditions ex...
Definition JsonReader.h:23
