UnrealMetadataConversions Struct Reference
#include <UnrealMetadataConversions.h>
static FIntPoint toIntPoint (const glm::ivec2 &vec2)
static FIntPoint toIntPoint (const std::string_view &string, const FIntPoint &defaultValue)
 Converts a std::string_view to a FIntPoint.
static FVector2D toVector2D (const glm::dvec2 &vec2)
static FVector2D toVector2D (const std::string_view &string, const FVector2D &defaultValue)
 Converts a std::string_view to a FVector2D.
static FIntVector toIntVector (const glm::ivec3 &vec3)
static FIntVector toIntVector (const std::string_view &string, const FIntVector &defaultValue)
 Converts a std::string_view to a FIntVector.
static FVector3f toVector3f (const glm::vec3 &vec3)
static FVector3f toVector3f (const std::string_view &string, const FVector3f &defaultValue)
static FVector toVector (const glm::dvec3 &vec3)
static FVector toVector (const std::string_view &string, const FVector &defaultValue)
static FVector4 toVector4 (const glm::dvec4 &vec4)
static FVector4 toVector4 (const std::string_view &string, const FVector4 &defaultValue)
static FMatrix toMatrix (const glm::dmat4 &mat4)
template<glm::length_t N, typename T>
static FString toString (const glm::vec< N, T > &from)
 Converts a glm::vecN to a FString.
static FString toString (const glm::mat< N, N, T > &from)
 Converts a glm::matN to a FString.
static FString toString (const std::string_view &from)
static FString toString (const std::string &from)
Definition at line 33 of file UnrealMetadataConversions.h.
◆ toIntPoint() [1/2]
static FIntPoint UnrealMetadataConversions::toIntPoint ( const glm::ivec2 & vec2)
static
◆ toIntPoint() [2/2]
static FIntPoint UnrealMetadataConversions::toIntPoint ( const std::string_view & string,
const FIntPoint & defaultValue )
static
This expects the values to be written in the "X=... Y=..." format. If this function fails to parse a FIntPoint, the default value is returned.
◆ toIntVector() [1/2]
static FIntVector UnrealMetadataConversions::toIntVector ( const glm::ivec3 & vec3)
static
◆ toIntVector() [2/2]
static FIntVector UnrealMetadataConversions::toIntVector ( const std::string_view & string,
const FIntVector & defaultValue )
static
This expects the values to be written in the "X=... Y=... Z=..." format. If this function fails to parse a FIntVector, the default value is returned.
stringThe std::string_view to be parsed.
defaultValueThe default value to be returned if conversion fails.
◆ toMatrix()
static FMatrix UnrealMetadataConversions::toMatrix ( const glm::dmat4 & mat4)
static
◆ toString() [1/4]
static FString UnrealMetadataConversions::toString ( const glm::mat< N, N, T > & from)
inlinestatic
This follows the format that ToString() functions call on the Unreal matrix equivalents. Each row is returned in square brackets, e.g. "[1 2 3 4]", with spaces in-between.
fromThe glm::matN to be converted.
Definition at line 109 of file UnrealMetadataConversions.h.
◆ toString() [2/4]
static FString UnrealMetadataConversions::toString ( const glm::vec< N, T > & from)
inlinestatic
This follows the format that ToString() functions call on the Unreal vector equivalents. For example, a glm::vec3 will return a string in the format "X=... Y=... Z=...".
fromThe glm::vecN to be converted.
Definition at line 88 of file UnrealMetadataConversions.h.
◆ toString() [3/4]
static FString UnrealMetadataConversions::toString ( const std::string & from)
static
◆ toString() [4/4]
static FString UnrealMetadataConversions::toString ( const std::string_view & from)
static
◆ toVector() [1/2]
static FVector UnrealMetadataConversions::toVector ( const glm::dvec3 & vec3)
static
◆ toVector() [2/2]
static FVector UnrealMetadataConversions::toVector ( const std::string_view & string,
const FVector & defaultValue )
static
◆ toVector2D() [1/2]
static FVector2D UnrealMetadataConversions::toVector2D ( const glm::dvec2 & vec2)
static
◆ toVector2D() [2/2]
static FVector2D UnrealMetadataConversions::toVector2D ( const std::string_view & string,
const FVector2D & defaultValue )
static
This uses FVector2D::InitFromString, which expects the values to be written in the "X=... Y=..." format. If this function fails to parse a FVector2D, the default value is returned.
◆ toVector3f() [1/2]
static FVector3f UnrealMetadataConversions::toVector3f ( const glm::vec3 & vec3)
static
◆ toVector3f() [2/2]
static FVector3f UnrealMetadataConversions::toVector3f ( const std::string_view & string,
const FVector3f & defaultValue )
static
◆ toVector4() [1/2]
static FVector4 UnrealMetadataConversions::toVector4 ( const glm::dvec4 & vec4)
static
◆ toVector4() [2/2]
static FVector4 UnrealMetadataConversions::toVector4 ( const std::string_view & string,
const FVector4 & defaultValue )
static
