FPropertyDescription Struct Reference
Description of a feature table property that should be encoded for access on the GPU. More...
#include <CesiumEncodedMetadataComponent.h>
FString Name
 The name of this property as it will be referenced in the material.
ECesiumPropertyComponentType_DEPRECATED ComponentType
 The GPU component type to coerce this property to.
ECesiumPropertyType_DEPRECATED Type
 The property type.
bool Normalized = false
 If ComponentType==Uint8, this indicates whether to normalize into a [0-1] range before accessing on the GPU.
Definition at line 66 of file CesiumEncodedMetadataComponent.h.
◆ ComponentType
ECesiumPropertyComponentType_DEPRECATED FPropertyDescription::ComponentType
Initial value:
Definition at line 81 of file CesiumEncodedMetadataComponent.h.
◆ Name
FString FPropertyDescription::Name
Definition at line 74 of file CesiumEncodedMetadataComponent.h.
◆ Normalized
bool FPropertyDescription::Normalized = false
Definition at line 101 of file CesiumEncodedMetadataComponent.h.
◆ Type
