Cesium for Unreal 2.31.0
Options for adjusting how point clouds are rendered using 3D Tiles. More...
#include <CesiumPointCloudShading.h>
| bool | operator== (const FCesiumPointCloudShading &OtherPointCloudShading) const |
| bool | operator!= (const FCesiumPointCloudShading &OtherPointCloudShading) const |
| bool | Attenuation = false |
| Whether or not to perform point attenuation. | |
| float | GeometricErrorScale = 1.0f |
| The scale to be applied to the tile's geometric error before it is used to compute attenuation. | |
| float | MaximumAttenuation = 0.0f |
| The maximum point attenuation in pixels. | |
| float | BaseResolution = 0.0f |
| The average base resolution for the dataset in meters. | |
Definition at line 13 of file CesiumPointCloudShading.h.
Definition at line 71 of file CesiumPointCloudShading.h.
Definition at line 63 of file CesiumPointCloudShading.h.
| bool FCesiumPointCloudShading::Attenuation = false |
Attenuation controls the size of the points rendered based on the geometric error of their tile.
Definition at line 21 of file CesiumPointCloudShading.h.
| float FCesiumPointCloudShading::BaseResolution = 0.0f |
For example, a base resolution of 0.05 assumes an original capture resolution of 5 centimeters between neighboring points.
This is used in place of geometric error when the tile's geometric error is
Definition at line 60 of file CesiumPointCloudShading.h.
| float FCesiumPointCloudShading::GeometricErrorScale = 1.0f |
Larger values will result in larger points.
Definition at line 32 of file CesiumPointCloudShading.h.
| float FCesiumPointCloudShading::MaximumAttenuation = 0.0f |
If this is zero, the Cesium3DTileset's maximumScreenSpaceError will be used as the maximum point attenuation.
Definition at line 44 of file CesiumPointCloudShading.h.
