UCesiumRuntimeSettings Class Reference
Stores runtime settings for the Cesium plugin. More...
#include <CesiumRuntimeSettings.h>
Inheritance diagram for UCesiumRuntimeSettings:
static void ClearRequestCache ()
 Clears all entries from the request cache database.
FString DefaultIonAccessTokenId_DEPRECATED
FString DefaultIonAccessToken_DEPRECATED
bool ScaleLevelOfDetailByDPI = true
bool EnableExperimentalOcclusionCullingFeature = false
 Uses Unreal's occlusion culling engine to drive Cesium 3D Tiles selection, reducing the detail of tiles that are occluded by other objects in the scene so that less data overall needs to be loaded and rendered.
int RequestsPerCachePrune = 10000
 The number of requests to handle before each prune of old cached results from the database.
int MaxCacheItems = 4096
 The maximum number of items that should be kept in the Sqlite database after pruning.
Definition at line 13 of file CesiumRuntimeSettings.h.
◆ ClearRequestCache()
static void UCesiumRuntimeSettings::ClearRequestCache ( )
static
◆ DefaultIonAccessToken_DEPRECATED
FString UCesiumRuntimeSettings::DefaultIonAccessToken_DEPRECATED
Definition at line 31 of file CesiumRuntimeSettings.h.
◆ DefaultIonAccessTokenId_DEPRECATED
FString UCesiumRuntimeSettings::DefaultIonAccessTokenId_DEPRECATED
Definition at line 23 of file CesiumRuntimeSettings.h.
◆ EnableExperimentalOcclusionCullingFeature
bool UCesiumRuntimeSettings::EnableExperimentalOcclusionCullingFeature = false
Definition at line 46 of file CesiumRuntimeSettings.h.
◆ MaxCacheItems
int UCesiumRuntimeSettings::MaxCacheItems = 4096
Definition at line 68 of file CesiumRuntimeSettings.h.
◆ RequestsPerCachePrune
int UCesiumRuntimeSettings::RequestsPerCachePrune = 10000
Definition at line 57 of file CesiumRuntimeSettings.h.
◆ ScaleLevelOfDetailByDPI
bool UCesiumRuntimeSettings::ScaleLevelOfDetailByDPI = true
Definition at line 38 of file CesiumRuntimeSettings.h.
