UCesiumPropertyTableBlueprintLibrary Class Reference
#include <CesiumPropertyTable.h>
Inheritance diagram for UCesiumPropertyTableBlueprintLibrary:
static ECesiumPropertyTableStatus GetPropertyTableStatus (UPARAM(ref) const FCesiumPropertyTable &PropertyTable)
 Gets the status of the property table.
static const FString & GetPropertyTableName (UPARAM(ref) const FCesiumPropertyTable &PropertyTable)
 Gets the name of the property table.
static int64 GetPropertyTableCount (UPARAM(ref) const FCesiumPropertyTable &PropertyTable)
 Gets the number of values each property in the table is expected to have.
static const TMap< FString, FCesiumPropertyTableProperty > & GetProperties (UPARAM(ref) const FCesiumPropertyTable &PropertyTable)
 Gets all the properties of the property table, mapped by property name.
static const TArray< FString > GetPropertyNames (UPARAM(ref) const FCesiumPropertyTable &PropertyTable)
 Gets the names of the properties in this property table.
static const FCesiumPropertyTableProperty & FindProperty (UPARAM(ref) const FCesiumPropertyTable &PropertyTable, const FString &PropertyName)
 Retrieve a FCesiumPropertyTableProperty by name.
static TMap< FString, FCesiumMetadataValue > GetMetadataValuesForFeature (UPARAM(ref) const FCesiumPropertyTable &PropertyTable, int64 FeatureID)
 Gets all of the property values for a given feature, mapped by property name.
static PRAGMA_DISABLE_DEPRECATION_WARNINGS TMap< FString, FString > GetMetadataValuesForFeatureAsStrings (UPARAM(ref) const FCesiumPropertyTable &PropertyTable, int64 FeatureID)
 Gets all of the property values for a given feature as strings, mapped by property name.
Definition at line 92 of file CesiumPropertyTable.h.
◆ FindProperty()
static const FCesiumPropertyTableProperty & UCesiumPropertyTableBlueprintLibrary::FindProperty ( UPARAM(ref) const FCesiumPropertyTable & PropertyTable,
const FString & PropertyName )
static
If the property table does not contain a property with that name, this returns an invalid FCesiumPropertyTableProperty.
PropertyTableThe property table.
PropertyNameThe name of the property to find.
◆ GetMetadataValuesForFeature()
static TMap< FString, FCesiumMetadataValue > UCesiumPropertyTableBlueprintLibrary::GetMetadataValuesForFeature ( UPARAM(ref) const FCesiumPropertyTable & PropertyTable,
int64 FeatureID )
static
This will only include values from valid property table properties.
If the feature ID is out-of-bounds, the returned map will be empty.
FeatureIDThe ID of the feature.
The property values mapped by property name.
◆ GetMetadataValuesForFeatureAsStrings()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS TMap< FString, FString > UCesiumPropertyTableBlueprintLibrary::GetMetadataValuesForFeatureAsStrings ( UPARAM(ref) const FCesiumPropertyTable & PropertyTable,
int64 FeatureID )
static
Array properties cannot be converted to strings, so empty strings will be returned for their values.
The property values as strings mapped by property name.
◆ GetProperties()
static const TMap< FString, FCesiumPropertyTableProperty > & UCesiumPropertyTableBlueprintLibrary::GetProperties ( UPARAM(ref) const FCesiumPropertyTable & PropertyTable)
static
◆ GetPropertyNames()
static const TArray< FString > UCesiumPropertyTableBlueprintLibrary::GetPropertyNames ( UPARAM(ref) const FCesiumPropertyTable & PropertyTable)
static
◆ GetPropertyTableCount()
static int64 UCesiumPropertyTableBlueprintLibrary::GetPropertyTableCount ( UPARAM(ref) const FCesiumPropertyTable & PropertyTable)
static
If an error occurred while parsing the property table, this returns zero.
◆ GetPropertyTableName()
static const FString & UCesiumPropertyTableBlueprintLibrary::GetPropertyTableName ( UPARAM(ref) const FCesiumPropertyTable & PropertyTable)
static
If no name was specified in the glTF extension, this returns an empty string.
◆ GetPropertyTableStatus()
static ECesiumPropertyTableStatus UCesiumPropertyTableBlueprintLibrary::GetPropertyTableStatus ( UPARAM(ref) const FCesiumPropertyTable & PropertyTable)
static
If an error occurred while parsing the property table from the glTF extension, this briefly conveys why.
