UCesiumPropertyArrayBlueprintLibrary Class Reference
Blueprint library functions for acting on an array value from a property in EXT_structural_metadata. More...
#include <CesiumPropertyArrayBlueprintLibrary.h>
Inheritance diagram for UCesiumPropertyArrayBlueprintLibrary:
static ECesiumMetadataBlueprintType GetElementBlueprintType (UPARAM(ref) const FCesiumPropertyArray &array)
 Gets the best-fitting Blueprints type for the elements of this array.
static FCesiumMetadataValueType GetElementValueType (UPARAM(ref) const FCesiumPropertyArray &array)
 Gets the true value type of the elements in the array.
static int64 GetArraySize (UPARAM(ref) const FCesiumPropertyArray &Array)
 Gets the number of elements in the array.
static FCesiumMetadataValue GetValue (UPARAM(ref) const FCesiumPropertyArray &Array, int64 Index)
 Retrieves an element from the array as a FCesiumMetadataValue.
static FString ToString (UPARAM(ref) const FCesiumPropertyArray &Array)
 Prints the contents of the array to a human-readable string in the format "[A, B, C, ... Z]".
static PRAGMA_DISABLE_DEPRECATION_WARNINGS ECesiumMetadataBlueprintType GetBlueprintComponentType (UPARAM(ref) const FCesiumPropertyArray &array)
static ECesiumMetadataTrueType_DEPRECATED GetTrueComponentType (UPARAM(ref) const FCesiumPropertyArray &array)
 Gets true type of the elements in the array.
static int64 GetSize (UPARAM(ref) const FCesiumPropertyArray &Array)
static bool GetBoolean (UPARAM(ref) const FCesiumPropertyArray &Array, int64 Index, bool DefaultValue=false)
 Retrieves an element from the array and attempts to convert it to a Boolean value.
static uint8 GetByte (UPARAM(ref) const FCesiumPropertyArray &Array, int64 Index, uint8 DefaultValue=0)
 Retrieves an element from the array and attempts to convert it to an unsigned 8-bit integer value.
static int32 GetInteger (UPARAM(ref) const FCesiumPropertyArray &Array, int64 Index, int32 DefaultValue=0)
 Retrieves an element from the array and attempts to convert it to a signed 32-bit integer value.
static int64 GetInteger64 (UPARAM(ref) const FCesiumPropertyArray &Array, int64 Index, int64 DefaultValue=0)
 This function is deprecated.
static float GetFloat (UPARAM(ref) const FCesiumPropertyArray &array, int64 index, float DefaultValue=0.0f)
 Retrieves an element from the array and attempts to convert it to a 32-bit floating-point value.
static double GetFloat64 (UPARAM(ref) const FCesiumPropertyArray &array, int64 index, double DefaultValue)
 Retrieves an element from the array and attempts to convert it to a 64-bit floating-point value.
static FString GetString (UPARAM(ref) const FCesiumPropertyArray &Array, int64 Index, const FString &DefaultValue="")
 Retrieves an element from the array and attempts to convert it to a string value.
Definition at line 14 of file CesiumPropertyArrayBlueprintLibrary.h.
◆ GetArraySize()
static int64 UCesiumPropertyArrayBlueprintLibrary::GetArraySize ( UPARAM(ref) const FCesiumPropertyArray & Array)
static
Returns 0 if the elements have an unknown type.
ArrayThe array.
The number of elements in the array.
◆ GetBlueprintComponentType()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS ECesiumMetadataBlueprintType UCesiumPropertyArrayBlueprintLibrary::GetBlueprintComponentType ( UPARAM(ref) const FCesiumPropertyArray & array)
static
arrayThe array.
◆ GetBoolean()
static bool UCesiumPropertyArrayBlueprintLibrary::GetBoolean ( UPARAM(ref) const FCesiumPropertyArray & Array,
int64 Index,
bool DefaultValue = false )
static
If the element is boolean, it is returned directly.
If the element is numeric, zero is converted to false, while any other value is converted to true.
If the element is a string, "0", "false", and "no" (case-insensitive) are converted to false, while "1", "true", and "yes" are converted to true. All other strings, including strings that can be converted to numbers, will return the default value.
Other types of elements will return the default value.
ArrayThe array.
IndexThe index of the array element to retrieve.
DefaultValueThe default value to use if the index is invalid or the element's value cannot be converted.
The element value.
◆ GetByte()
static uint8 UCesiumPropertyArrayBlueprintLibrary::GetByte ( UPARAM(ref) const FCesiumPropertyArray & Array,
int64 Index,
uint8 DefaultValue = 0 )
static
If the element is an integer and between 0 and 255, it is returned directly.
If the element is a floating-point number, it is truncated (rounded toward zero).
If the element is a boolean, 0 is returned for false and 1 for true.
If the element is a string and the entire string can be parsed as an integer between 0 and 255, the parsed value is returned. The string is parsed in a locale-independent way and does not support use of a comma or other character to group digits.
Otherwise, the default value is returned.
ArrayThe array.
The element value.
◆ GetElementBlueprintType()
static ECesiumMetadataBlueprintType UCesiumPropertyArrayBlueprintLibrary::GetElementBlueprintType ( UPARAM(ref) const FCesiumPropertyArray & array)
static
arrayThe array.
◆ GetElementValueType()
static FCesiumMetadataValueType UCesiumPropertyArrayBlueprintLibrary::GetElementValueType ( UPARAM(ref) const FCesiumPropertyArray & array)
static
Many of these types are not accessible from Blueprints, but can be converted to a Blueprint-accessible type.
arrayThe array.
◆ GetFloat()
static float UCesiumPropertyArrayBlueprintLibrary::GetFloat ( UPARAM(ref) const FCesiumPropertyArray & array,
int64 index,
float DefaultValue = 0.0f )
static
If the element is a single-precision floating-point number, is is returned.
If the element is an integer or double-precision floating-point number, it is converted to the closest representable single-precision floating-point number.
If the element is a boolean, 0.0 is returned for false and 1.0 for true.
If the element is a string and the entire string can be parsed as a number, the parsed value is returned. The string is parsed in a locale-independent way and does not support use of a comma or other character to group digits.
arrayThe array.
indexThe index of the array element to retrieve.
The element value.
◆ GetFloat64()
static double UCesiumPropertyArrayBlueprintLibrary::GetFloat64 ( UPARAM(ref) const FCesiumPropertyArray & array,
int64 index,
double DefaultValue )
static
If the element is a single- or double-precision floating-point number, is is returned.
If the element is an integer, it is converted to the closest representable double-precision floating-point number.
arrayThe array.
The element value.
◆ GetInteger()
static int32 UCesiumPropertyArrayBlueprintLibrary::GetInteger ( UPARAM(ref) const FCesiumPropertyArray & Array,
int64 Index,
int32 DefaultValue = 0 )
static
If the element is an integer and between -2,147,483,647 and 2,147,483,647, it is returned directly.
If the element is a string and the entire string can be parsed as an integer in the valid range, the parsed value is returned. If it can be parsed as a floating-point number, the parsed value is truncated (rounded toward zero). In either case, the string is parsed in a locale-independent way and does not support use of a comma or other character to group digits.
ArrayThe array.
The element value.
◆ GetInteger64()
static int64 UCesiumPropertyArrayBlueprintLibrary::GetInteger64 ( UPARAM(ref) const FCesiumPropertyArray & Array,
int64 Index,
int64 DefaultValue = 0 )
static
Use Cesium > Metadata > Property Array > GetValue instead.
Retrieves an element from the array and attempts to convert it to a signed 64-bit integer value.
If the element is an integer and between -2^63-1 and 2^63-1, it is returned directly.
ArrayThe array.
The element value.
◆ GetSize()
static int64 UCesiumPropertyArrayBlueprintLibrary::GetSize ( UPARAM(ref) const FCesiumPropertyArray & Array)
static
ArrayThe array.
◆ GetString()
static FString UCesiumPropertyArrayBlueprintLibrary::GetString ( UPARAM(ref) const FCesiumPropertyArray & Array,
int64 Index,
const FString & DefaultValue = "" )
static
Numeric elements are converted to a string with FString::Format, which uses the current locale.
Boolean elements are converted to "true" or "false".
String elements are returned directly.
ArrayThe array.
The element value.
◆ GetTrueComponentType()
static ECesiumMetadataTrueType_DEPRECATED UCesiumPropertyArrayBlueprintLibrary::GetTrueComponentType ( UPARAM(ref) const FCesiumPropertyArray & array)
static
arrayThe array.
◆ GetValue()
static FCesiumMetadataValue UCesiumPropertyArrayBlueprintLibrary::GetValue ( UPARAM(ref) const FCesiumPropertyArray & Array,
int64 Index )
static
The value can then be retrieved as a specific Blueprints type.
If the index is out-of-bounds, this returns a bogus FCesiumMetadataValue of an unknown type.
ArrayThe array.
The element as a FCesiumMetadataValue.
◆ ToString()
static FString UCesiumPropertyArrayBlueprintLibrary::ToString ( UPARAM(ref) const FCesiumPropertyArray & Array)
static
ArrayThe array.
A string capturing the contents of the array.
