UCesiumMetadataUtilityBlueprintLibrary Class Reference
#include <CesiumMetadataUtilityBlueprintLibrary.h>
Inheritance diagram for UCesiumMetadataUtilityBlueprintLibrary:
static PRAGMA_DISABLE_DEPRECATION_WARNINGS const FCesiumMetadataPrimitive & GetPrimitiveMetadata (const UPrimitiveComponent *component)
 Gets the primitive metadata of a glTF primitive component.
static TMap< FString, FCesiumMetadataValue > GetMetadataValuesForFace (const UPrimitiveComponent *component, int64 faceID)
 Gets the metadata of a face of a glTF primitive component.
static TMap< FString, FString > GetMetadataValuesAsStringForFace (const UPrimitiveComponent *component, int64 faceID)
 Gets the metadata as string of a face of a glTF primitive component.
static int64 GetFeatureIDFromFaceID (UPARAM(ref) const FCesiumMetadataPrimitive &Primitive, UPARAM(ref) const FCesiumFeatureIdAttribute &FeatureIDAttribute, int64 FaceID)
 Gets the feature ID associated with a given face for a feature id attribute.
Definition at line 15 of file CesiumMetadataUtilityBlueprintLibrary.h.
◆ GetFeatureIDFromFaceID()
static int64 UCesiumMetadataUtilityBlueprintLibrary::GetFeatureIDFromFaceID ( UPARAM(ref) const FCesiumMetadataPrimitive & Primitive,
UPARAM(ref) const FCesiumFeatureIdAttribute & FeatureIDAttribute,
int64 FaceID )
static
◆ GetMetadataValuesAsStringForFace()
static TMap< FString, FString > UCesiumMetadataUtilityBlueprintLibrary::GetMetadataValuesAsStringForFace ( const UPrimitiveComponent * component,
int64 faceID )
static
If the component is not a Cesium glTF primitive component, the returned metadata is empty. If the primitive has multiple feature tables, the metadata in the first table is returned.
◆ GetMetadataValuesForFace()
static TMap< FString, FCesiumMetadataValue > UCesiumMetadataUtilityBlueprintLibrary::GetMetadataValuesForFace ( const UPrimitiveComponent * component,
int64 faceID )
static
◆ GetPrimitiveMetadata()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS const FCesiumMetadataPrimitive & UCesiumMetadataUtilityBlueprintLibrary::GetPrimitiveMetadata ( const UPrimitiveComponent * component)
static
If component is not a Cesium glTF primitive component, the returned metadata is empty
