UCesiumLoadGeoJsonDocumentFromIonAsyncAction Class Reference
#include <CesiumGeoJsonDocument.h>
Inheritance diagram for UCesiumLoadGeoJsonDocumentFromIonAsyncAction:
virtual void Activate () override
static UCesiumLoadGeoJsonDocumentFromIonAsyncAction * LoadFromIon (int64 AssetId, const FString &IonAccessToken, const UCesiumIonServer *CesiumIonServer=nullptr)
 Attempts to load a GeoJSON document from Cesium ion.
FCesiumGeoJsonDocumentAsyncLoadDelegate OnLoadResult
int64 AssetId
FString IonAccessToken
const UCesiumIonServer * CesiumIonServer
Definition at line 99 of file CesiumGeoJsonDocument.h.
◆ Activate()
virtual void UCesiumLoadGeoJsonDocumentFromIonAsyncAction::Activate ( )
overridevirtual
◆ LoadFromIon()
static UCesiumLoadGeoJsonDocumentFromIonAsyncAction * UCesiumLoadGeoJsonDocumentFromIonAsyncAction::LoadFromIon ( int64 AssetId,
const FString & IonAccessToken,
const UCesiumIonServer * CesiumIonServer = nullptr )
static
If CesiumIonServer is not assigned, then the default server for the project will be used instead. Likewise, the server's default ion access token will be used if IonAccessToken is empty.
If successful, Success will be true and Document will contain the loaded document.
◆ AssetId
int64 UCesiumLoadGeoJsonDocumentFromIonAsyncAction::AssetId
Definition at line 129 of file CesiumGeoJsonDocument.h.
◆ CesiumIonServer
const UCesiumIonServer* UCesiumLoadGeoJsonDocumentFromIonAsyncAction::CesiumIonServer
Definition at line 133 of file CesiumGeoJsonDocument.h.
◆ IonAccessToken
FString UCesiumLoadGeoJsonDocumentFromIonAsyncAction::IonAccessToken
Definition at line 130 of file CesiumGeoJsonDocument.h.
◆ OnLoadResult
FCesiumGeoJsonDocumentAsyncLoadDelegate UCesiumLoadGeoJsonDocumentFromIonAsyncAction::OnLoadResult
Definition at line 125 of file CesiumGeoJsonDocument.h.
