CesiumSampleHeightResult.h
5#include "CesiumSampleHeightResult.generated.h"
6
7/**
8 * The result of sampling the height on a tileset at the given cartographic
9 * position.
10 */
11USTRUCT(BlueprintType)
12struct CESIUMRUNTIME_API FCesiumSampleHeightResult {
13 GENERATED_BODY()
14
15 /**
16 * The Longitude (X) and Latitude (Y) are the same values provided on input.
17 * The Height (Z) is the height sampled from the tileset if the SampleSuccess
18 * property is true, or the original height provided on input if SampleSuccess
19 * is false.
20 */
21 UPROPERTY(BlueprintReadWrite, Category = "Cesium")
22 FVector LongitudeLatitudeHeight = {0.0, 0.0, 0.0};
23
24 /**
25 * True if the height as sampled from the tileset successfully. False if the
26 * tileset doesn't have any height at that position, or if something went
27 * wrong. If something went wrong, the Warnings pin of the sampling function
28 * will have more information about the problem.
29 */
30 UPROPERTY(BlueprintReadWrite, Category = "Cesium")
31 bool SampleSuccess = false;
32};
The result of sampling the height on a tileset at the given cartographic position.
bool SampleSuccess
