Cesium for Unity 1.26.1
CesiumForUnity.CesiumVectorPointStyle Struct Reference
The style used to draw points. More...
double radius
 The radius of the point in pixels.
bool fill
 Whether the point should be filled.
CesiumVectorPolygonFillStyle fillStyle
 If fill is true, this style will be used when filling the point.
bool outline
 Whether the point should be outlined.
CesiumVectorLineStyle outlineStyle
 If outline is true, this style will be used when outlining the point.
Properties
static CesiumVectorPointStyle Default [get]
 Creates a default point style with a 5 pixel radius, fill enabled, and outline disabled.
Definition at line 163 of file CesiumVectorStyle.cs.
◆ fill
bool CesiumForUnity.CesiumVectorPointStyle.fill
Definition at line 176 of file CesiumVectorStyle.cs.
◆ fillStyle
CesiumVectorPolygonFillStyle CesiumForUnity.CesiumVectorPointStyle.fillStyle
Definition at line 182 of file CesiumVectorStyle.cs.
◆ outline
bool CesiumForUnity.CesiumVectorPointStyle.outline
Definition at line 188 of file CesiumVectorStyle.cs.
◆ outlineStyle
CesiumVectorLineStyle CesiumForUnity.CesiumVectorPointStyle.outlineStyle
Definition at line 194 of file CesiumVectorStyle.cs.
◆ radius
double CesiumForUnity.CesiumVectorPointStyle.radius
Definition at line 170 of file CesiumVectorStyle.cs.
Property Documentation
◆ Default
CesiumVectorPointStyle CesiumForUnity.CesiumVectorPointStyle.Default
staticget
Fill is enabled by default because the underlying native point style renders nothing when neither fill nor outline is set.
Definition at line 204 of file CesiumVectorStyle.cs.
