Cesium for Unity 1.26.1
CesiumVectorStyle.cs
1using System;
2using UnityEngine;
3
4namespace CesiumForUnity
5{
10 {
14 Normal = 0,
15
27 }
28
33 {
38 Pixels = 0,
39
44 }
45
49 [Serializable]
51 {
55 [Tooltip("The color to be used.")]
56 public Color32 color;
57
61 [Tooltip("The color mode to be used.")]
63
67 [Tooltip("The width of the line or stroke, with the unit specified by widthMode.")]
68 [Min(0)]
69 public double width;
70
74 [Tooltip("The mode to use when interpreting width.")]
76
81 {
82 color = new Color32(255, 255, 255, 255),
84 width = 1.0,
86 };
87 }
88
92 [Serializable]
94 {
98 [Tooltip("The color to be used.")]
99 public Color32 color;
100
104 [Tooltip("The color mode to be used.")]
106
111 {
112 color = new Color32(255, 255, 255, 255),
114 };
115 }
116
120 [Serializable]
122 {
126 [Tooltip("Whether the polygon should be filled.")]
127 public bool fill;
128
132 [Tooltip("If fill is true, this style will be used when filling the polygon.")]
134
138 [Tooltip("Whether the polygon should be outlined.")]
139 public bool outline;
140
144 [Tooltip("If outline is true, this style will be used when outlining the polygon.")]
146
157 }
158
162 [Serializable]
164 {
168 [Tooltip("The radius of the point in pixels.")]
169 [Min(0)]
170 public double radius;
171
175 [Tooltip("Whether the point should be filled.")]
176 public bool fill;
177
181 [Tooltip("If fill is true, this style will be used when filling the point.")]
183
187 [Tooltip("Whether the point should be outlined.")]
188 public bool outline;
189
193 [Tooltip("If outline is true, this style will be used when outlining the point.")]
195
212 }
213
217 [Serializable]
218 public struct CesiumVectorStyle
219 {
223 [Tooltip("Styles to use when drawing polylines and stroking shapes.")]
225
229 [Tooltip("Styles to use when drawing polygons.")]
231
235 [Tooltip("Styles to use when drawing points.")]
237
247 }
248}
CesiumVectorLineWidthMode
The mode used to render polylines and strokes.
@ Meters
The line width represents the physical size of the line in meters.
@ Pixels
The line width represents the number of pixels the line will take up, regardless of LOD.
CesiumVectorColorMode
The mode used to interpret the color value provided in a style.
@ Random
The color will be chosen randomly.
The style used to draw polylines and strokes.
CesiumVectorLineWidthMode widthMode
Color32 color
CesiumVectorColorMode colorMode
static CesiumVectorLineStyle Default
Creates a default line style with white color and 1 pixel width.
double width
The style used to draw points.
CesiumVectorPolygonFillStyle fillStyle
static CesiumVectorPointStyle Default
Creates a default point style with a 5 pixel radius, fill enabled, and outline disabled.
CesiumVectorLineStyle outlineStyle
double radius
bool outline
bool fill
static CesiumVectorPolygonFillStyle Default
Creates a default polygon fill style with white color.
The style used to draw polygons.
static CesiumVectorPolygonStyle Default
Creates a default polygon style with fill enabled and outline disabled.
bool outline
bool fill
Style information to use when drawing vector data.
CesiumVectorLineStyle lineStyle
static CesiumVectorStyle Default
Creates a default vector style.
CesiumVectorPolygonStyle polygonStyle
CesiumVectorPointStyle pointStyle
