Cesium for Unity 1.26.1
CesiumForUnity.CesiumWgs84Ellipsoid Class Reference
Holds static methods for ellipsoid math and transforming between geospatial coordinate systems using the World Geodetic System (WGS84) standard. More...
static partial double3 GetRadii ()
 Gets the radii of the ellipsoid in its x-, y-, and z-directions.
static double GetMaximumRadius ()
 Gets the maximum radius of the ellipsoid in any dimension.
static double GetMinimumRadius ()
 Gets the minimum radius of the ellipsoid in any dimension.
static partial? double3 ScaleToGeodeticSurface (double3 earthCenteredEarthFixed)
 Scale the given Earth-Centered, Earth-Fixed position along the geodetic surface normal so that it is on the surface of the ellipsoid.
static partial double3 GeodeticSurfaceNormal (double3 earthCenteredEarthFixed)
 Computes the normal of the plane tangent to the surface of the ellipsoid at the provided Earth-Centered, Earth-Fixed position.
static partial double3 LongitudeLatitudeHeightToEarthCenteredEarthFixed (double3 longitudeLatitudeHeight)
 Convert longitude, latitude, and height to Earth-Centered, Earth-Fixed (ECEF) coordinates.
static partial double3 EarthCenteredEarthFixedToLongitudeLatitudeHeight (double3 earthCenteredEarthFixed)
 Convert Earth-Centered, Earth-Fixed (ECEF) coordinates to longitude, latitude, and height.
Definition at line 11 of file CesiumWgs84Ellipsoid.cs.
◆ EarthCenteredEarthFixedToLongitudeLatitudeHeight()
static partial double3 CesiumForUnity.CesiumWgs84Ellipsoid.EarthCenteredEarthFixedToLongitudeLatitudeHeight ( double3 earthCenteredEarthFixed)
static
earthCenteredEarthFixedThe ECEF coordinates in meters.
The longitude (X) and latitude (Y) are in degrees. The height (Z) is in meters above the ellipsoid, and should not be confused with a geoid, orthometric, or mean sea level height.
◆ GeodeticSurfaceNormal()
static partial double3 CesiumForUnity.CesiumWgs84Ellipsoid.GeodeticSurfaceNormal ( double3 earthCenteredEarthFixed)
static
earthCenteredEarthFixedThe ECEF position in meters.
The normal at the ECEF position
◆ GetMaximumRadius()
static double CesiumForUnity.CesiumWgs84Ellipsoid.GetMaximumRadius ( )
inlinestatic
The maximum radius of the ellipsoid.
Definition at line 23 of file CesiumWgs84Ellipsoid.cs.
◆ GetMinimumRadius()
static double CesiumForUnity.CesiumWgs84Ellipsoid.GetMinimumRadius ( )
inlinestatic
The minimum radius of the ellipsoid.
Definition at line 32 of file CesiumWgs84Ellipsoid.cs.
◆ GetRadii()
static partial double3 CesiumForUnity.CesiumWgs84Ellipsoid.GetRadii ( )
static
The radii of the ellipsoid in its x-, y-, and z-directions.
◆ LongitudeLatitudeHeightToEarthCenteredEarthFixed()
static partial double3 CesiumForUnity.CesiumWgs84Ellipsoid.LongitudeLatitudeHeightToEarthCenteredEarthFixed ( double3 longitudeLatitudeHeight)
static
longitudeLatitudeHeightThe longitude (X) and latitude (Y) are in degrees. The height (Z) is in meters above the ellipsoid, and should not be confused with a geoid, orthometric, or mean sea level height.
◆ ScaleToGeodeticSurface()
static partial? double3 CesiumForUnity.CesiumWgs84Ellipsoid.ScaleToGeodeticSurface ( double3 earthCenteredEarthFixed)
static
If the position is at the center of the ellipsoid, the result will be null.
The scaled position, or null if the position is at the center of the ellipsoid.
