Cesium for Unity 1.26.1
CesiumWgs84Ellipsoid.cs
1using Reinterop;
2using UnityEngine;
3using Unity.Mathematics;
5namespace CesiumForUnity
6{
10 [ReinteropNativeImplementation("CesiumForUnityNative::CesiumWgs84EllipsoidImpl", "CesiumWgs84EllipsoidImpl.h", staticOnly: true)]
11 public static partial class CesiumWgs84Ellipsoid
12 {
17 public static partial double3 GetRadii();
18
23 public static double GetMaximumRadius()
24 {
25 return math.cmax(CesiumWgs84Ellipsoid.GetRadii());
26 }
27
32 public static double GetMinimumRadius()
33 {
34 return math.cmin(CesiumWgs84Ellipsoid.GetRadii());
35 }
36
44 public static partial double3? ScaleToGeodeticSurface(double3 earthCenteredEarthFixed);
45
52 public static partial double3 GeodeticSurfaceNormal(double3 earthCenteredEarthFixed);
53
61 public static partial double3
62 LongitudeLatitudeHeightToEarthCenteredEarthFixed(double3 longitudeLatitudeHeight);
63
72 public static partial double3
73 EarthCenteredEarthFixedToLongitudeLatitudeHeight(double3 earthCenteredEarthFixed);
74 }
75}
Holds static methods for ellipsoid math and transforming between geospatial coordinate systems using ...
static partial double3 LongitudeLatitudeHeightToEarthCenteredEarthFixed(double3 longitudeLatitudeHeight)
Convert longitude, latitude, and height to Earth-Centered, Earth-Fixed (ECEF) coordinates.
static partial double3 EarthCenteredEarthFixedToLongitudeLatitudeHeight(double3 earthCenteredEarthFixed)
Convert Earth-Centered, Earth-Fixed (ECEF) coordinates to longitude, latitude, and height.
Gets the radii of the ellipsoid in its x-, y-, and z-directions.
Gets the maximum radius of the ellipsoid in any dimension.
static partial? double3 ScaleToGeodeticSurface(double3 earthCenteredEarthFixed)
Scale the given Earth-Centered, Earth-Fixed position along the geodetic surface normal so that it is ...
Computes the normal of the plane tangent to the surface of the ellipsoid at the provided Earth-Center...
Gets the minimum radius of the ellipsoid in any dimension.
