Cesium for Unity 1.26.1
CesiumForUnity.CesiumWebMapServiceRasterOverlay Class Reference
A raster overlay that directly accesses a Web Map Service (WMS) server. More...
Inheritance diagram for CesiumForUnity.CesiumWebMapServiceRasterOverlay:
Protected Member Functions
Properties
string baseUrl [get, set]
 The base URL of the Web Map Service (WMS).
string layers [get, set]
 Comma-separated layer names to request from the server.
int tileWidth [get, set]
 Image width.
int tileHeight [get, set]
 Image height.
int minimumLevel [get, set]
 The minimum zoom level.
int maximumLevel [get, set]
 The maximum zoom level.
string materialKey [get, set]
Additional Inherited Members
void AddToTileset ()
void RemoveFromTileset ()
void Refresh ()
https://www.ogc.org/standards/wms
Definition at line 15 of file CesiumWebMapServiceRasterOverlay.cs.
◆ AddToTileset()
override partial void CesiumForUnity.CesiumWebMapServiceRasterOverlay.AddToTileset ( Cesium3DTileset tileset)
protected
◆ RemoveFromTileset()
override partial void CesiumForUnity.CesiumWebMapServiceRasterOverlay.RemoveFromTileset ( Cesium3DTileset tileset)
protected
Property Documentation
◆ baseUrl
string CesiumForUnity.CesiumWebMapServiceRasterOverlay.baseUrl
getset
This URL should not include query parameters. For example: https://services.ga.gov.au/gis/services/NM_Culture_and_Infrastructure/MapServer/WMSServer
Definition at line 27 of file CesiumWebMapServiceRasterOverlay.cs.
◆ layers
string CesiumForUnity.CesiumWebMapServiceRasterOverlay.layers
getset
Definition at line 43 of file CesiumWebMapServiceRasterOverlay.cs.
◆ maximumLevel
int CesiumForUnity.CesiumWebMapServiceRasterOverlay.maximumLevel
getset
Definition at line 114 of file CesiumWebMapServiceRasterOverlay.cs.
◆ minimumLevel
int CesiumForUnity.CesiumWebMapServiceRasterOverlay.minimumLevel
getset
Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
Definition at line 97 of file CesiumWebMapServiceRasterOverlay.cs.
◆ tileHeight
int CesiumForUnity.CesiumWebMapServiceRasterOverlay.tileHeight
getset
Image height.
Definition at line 75 of file CesiumWebMapServiceRasterOverlay.cs.
◆ tileWidth
int CesiumForUnity.CesiumWebMapServiceRasterOverlay.tileWidth
getset
Image width.
Definition at line 59 of file CesiumWebMapServiceRasterOverlay.cs.
