Cesium for Unity 1.26.1
CesiumForUnity.CesiumPolygonRasterOverlay Class Reference
A raster overlay that rasterizes polygons and drapes them over the tileset. More...
Inheritance diagram for CesiumForUnity.CesiumPolygonRasterOverlay:
Protected Member Functions
Properties
List< CesiumCartographicPolygon > polygons [get, set]
 The polygons to rasterize for this overlay.
bool invertSelection [get, set]
 Whether to invert the selection specified by the polygons.
bool excludeSelectedTiles [get, set]
 Whether tiles that fall entirely within the rasterized selection should be excluded from loading and rendering.
string materialKey [get, set]
Additional Inherited Members
void AddToTileset ()
void RemoveFromTileset ()
void Refresh ()
This is useful for clipping out parts of a tileset or applying specific material effects in an area.
Polygon raster overlays will only work in Unity 2022.2 or later.
Definition at line 23 of file CesiumPolygonRasterOverlay.cs.
◆ AddToTileset()
override partial void CesiumForUnity.CesiumPolygonRasterOverlay.AddToTileset ( Cesium3DTileset tileset)
protected
◆ RemoveFromTileset()
override partial void CesiumForUnity.CesiumPolygonRasterOverlay.RemoveFromTileset ( Cesium3DTileset tileset)
protected
Property Documentation
◆ excludeSelectedTiles
bool CesiumForUnity.CesiumPolygonRasterOverlay.excludeSelectedTiles
getset
For better performance, this should be enabled when this overlay will be used for clipping. But when this overlay is used for other effects, this option should be disabled to avoid missing tiles.
Note that if invertSelection is true, this will cull tiles that are outside of all the polygons. If it is false, this will cull tiles that are completely inside at least one polygon.
Definition at line 87 of file CesiumPolygonRasterOverlay.cs.
◆ invertSelection
bool CesiumForUnity.CesiumPolygonRasterOverlay.invertSelection
getset
When this setting is false, the areas inside the polygons are rasterized and therefore hidden from the rest of the tileset. In other words, they appear to cut holes in the tileset.
When this setting is true, the areas outside of all the polygons will be rasterized instead. This will hide everything except for the areas inside the polygons.
Definition at line 58 of file CesiumPolygonRasterOverlay.cs.
◆ polygons
List<CesiumCartographicPolygon> CesiumForUnity.CesiumPolygonRasterOverlay.polygons
getset
Definition at line 31 of file CesiumPolygonRasterOverlay.cs.
