Cesium for Unity 1.26.1
Options for adjusting how point clouds are rendered using 3D Tiles. More...
Properties | |
| bool | attenuation [get, set] |
| Whether or not to perform point attenuation. | |
| float | geometricErrorScale [get, set] |
| The scale to be applied to the tile's geometric error before it is used to compute attenuation. | |
| float | maximumAttenuation [get, set] |
| The maximum point attenuation in pixels. | |
| float | baseResolution [get, set] |
| The average base resolution for the dataset in meters. | |
Definition at line 10 of file CesiumPointCloudShading.cs.
getset |
Attenuation controls the size of the points rendered based on the geometric error of their tile.
Definition at line 19 of file CesiumPointCloudShading.cs.
getset |
For example, a base resolution of 0.05 assumes an original capture resolution of 5 centimeters between neighboring points.
This is used in place of geometric error when the tile's geometric error is 0. If this value is zero, each tile with a geometric error of 0 will have its geometric error approximated instead.
Definition at line 70 of file CesiumPointCloudShading.cs.
getset |
Larger values will result in larger points.
Definition at line 32 of file CesiumPointCloudShading.cs.
getset |
If this is zero, the Cesium3DTileset's maximumScreenSpaceError will be used as the maximum point attenuation.
Definition at line 48 of file CesiumPointCloudShading.cs.
