Cesium for Unity 1.26.1
CesiumForUnity.CesiumIonRasterOverlay Class Reference
A CesiumRasterOverlay that uses an IMAGERY asset from Cesium ion. More...
Inheritance diagram for CesiumForUnity.CesiumIonRasterOverlay:
Protected Member Functions
Properties
long ionAssetID [get, set]
 The ID of the Cesium ion asset to use.
string ionAccessToken [get, set]
 The access token to use to access the Cesium ion resource.
CesiumIonServer ionServer [get, set]
 The Cesium ion server from which this raster overlay is loaded.
string assetOptions [get, set]
 Extra options to pass to Cesium ion when accessing the asset.
string materialKey [get, set]
Additional Inherited Members
void AddToTileset ()
void RemoveFromTileset ()
void Refresh ()
Definition at line 13 of file CesiumIonRasterOverlay.cs.
◆ AddToTileset()
override partial void CesiumForUnity.CesiumIonRasterOverlay.AddToTileset ( Cesium3DTileset tileset)
protected
◆ RemoveFromTileset()
override partial void CesiumForUnity.CesiumIonRasterOverlay.RemoveFromTileset ( Cesium3DTileset tileset)
protected
Property Documentation
◆ assetOptions
string CesiumForUnity.CesiumIonRasterOverlay.assetOptions
getset
This should be a JSON string.
Definition at line 88 of file CesiumIonRasterOverlay.cs.
◆ ionAccessToken
string CesiumForUnity.CesiumIonRasterOverlay.ionAccessToken
getset
Definition at line 37 of file CesiumIonRasterOverlay.cs.
◆ ionAssetID
long CesiumForUnity.CesiumIonRasterOverlay.ionAssetID
getset
Definition at line 21 of file CesiumIonRasterOverlay.cs.
◆ ionServer
CesiumIonServer CesiumForUnity.CesiumIonRasterOverlay.ionServer
getset
Definition at line 53 of file CesiumIonRasterOverlay.cs.
