Cesium for Unity 1.26.1
CesiumForUnity.CesiumIonServer Class Reference
Defines a Cesium ion Server. More...
Inheritance diagram for CesiumForUnity.CesiumIonServer:
string serverUrl = "https://ion.cesium.com"
 The main URL of the Cesium ion server.
string apiUrl = "https://api.cesium.com"
 The URL of the main API endpoint of the Cesium ion server.
long oauth2ApplicationID = 381
 The application ID to use to log in to this server using OAuth2.
string defaultIonAccessTokenId = ""
 The ID of the default access token to use to access Cesium ion assets at runtime.
string defaultIonAccessToken = ""
 The default token used to access Cesium ion assets at runtime.
Properties
static CesiumIonServer defaultServer [get]
 Gets the default Cesium ion Server (ion.cesium.com).
static CesiumIonServer serverForNewObjects [get, set]
 Gets the current Cesium ion server that should be assigned to newly-created objects.
This may be the public (SaaS) Cesium ion server at ion.cesium.com, or it may be a self-hosted instance.
Definition at line 13 of file CesiumIonServer.cs.
◆ apiUrl
string CesiumForUnity.CesiumIonServer.apiUrl = "https://api.cesium.com"
For example, for the default, public Cesium ion server, this is https://api.cesium.com. If left blank, the API URL is automatically inferred from the Server URL.
Definition at line 26 of file CesiumIonServer.cs.
◆ defaultIonAccessToken
string CesiumForUnity.CesiumIonServer.defaultIonAccessToken = ""
This token is embedded in packaged games for use at runtime.
Definition at line 47 of file CesiumIonServer.cs.
◆ defaultIonAccessTokenId
string CesiumForUnity.CesiumIonServer.defaultIonAccessTokenId = ""
This property may be an empty string, in which case the ID is found by searching the logged-in Cesium ion account for the DefaultIonAccessToken.
Definition at line 41 of file CesiumIonServer.cs.
◆ oauth2ApplicationID
long CesiumForUnity.CesiumIonServer.oauth2ApplicationID = 381
This OAuth2 application must be configured on the server with the exact URL http://127.0.0.1/cesium-for-unreal/oauth2/callback.
Definition at line 33 of file CesiumIonServer.cs.
◆ serverUrl
string CesiumForUnity.CesiumIonServer.serverUrl = "https://ion.cesium.com"
For example, the server URL for the public Cesium ion is https://ion.cesium.com.
Definition at line 19 of file CesiumIonServer.cs.
Property Documentation
◆ defaultServer
CesiumIonServer CesiumForUnity.CesiumIonServer.defaultServer
staticget
It is expected to be found at Assets/CesiumSettings/CesiumIonServers/ion.cesium.com. In the Editor, it will be created if it does not already exist, so this method always returns a valid instance. At runtime, this method returns null if the object does not exist.
Definition at line 64 of file CesiumIonServer.cs.
◆ serverForNewObjects
CesiumIonServer CesiumForUnity.CesiumIonServer.serverForNewObjects
staticgetset
Definition at line 120 of file CesiumIonServer.cs.
