Cesium for Unity 1.26.1
Allows access to a particular feature of CesiumMetadata. More...
| partial sbyte | GetInt8 (string property, sbyte defaultValue) |
| Gets the value of the specified property as a signed byte. | |
| partial byte | GetUInt8 (string property, byte defaultValue) |
| Gets the value of the specified property as a byte. | |
| partial Int16 | GetInt16 (string property, Int16 defaultValue) |
| Gets the value of the specified property as a signed 16-bit integer. | |
| partial UInt16 | GetUInt16 (string property, UInt16 defaultValue) |
| Gets the value of the specified property as an unsigned 16-bit integer. | |
| partial Int32 | GetInt32 (string property, Int32 defaultValue) |
| Gets the value of the specified property as a signed 32-bit integer. | |
| partial UInt32 | GetUInt32 (string property, UInt32 defaultValue) |
| Gets the value of the specified property as an unsigned 32-bit integer. | |
| partial Int64 | GetInt64 (string property, Int64 defaultValue) |
| Gets the value of the specified property as a signed 64-bit integer. | |
| partial UInt64 | GetUInt64 (string property, UInt64 defaultValue) |
| Gets the value of the specified property as an unsigned 64-bit integer. | |
| partial float | GetFloat32 (string property, float defaultValue) |
| Gets the value of the specified property as a 32-bit floating-point number. | |
| partial double | GetFloat64 (string property, double defaultValue) |
| Gets the value of the specified property as a 64-bit floating-point number. | |
| partial Boolean | GetBoolean (string property, Boolean defaultValue) |
| Gets the value of the specified property as a boolean value. | |
| partial String | GetString (string property, String defaultValue) |
| Gets the value of the specified property as a string. | |
| partial sbyte | GetComponentInt8 (string property, int index, sbyte defaultValue) |
| Gets the value of the specified property from an array as a signed byte. | |
| partial byte | GetComponentUInt8 (string property, int index, byte defaultValue) |
| Gets the value of the specified property from an array as a byte. | |
| partial Int16 | GetComponentInt16 (string property, int index, Int16 defaultValue) |
| Gets the value of the specified property from an array as a signed 16-bit integer. | |
| partial UInt16 | GetComponentUInt16 (string property, int index, UInt16 defaultValue) |
| Gets the value of the specified property from an array as an unsigned 16-bit integer. | |
| partial Int32 | GetComponentInt32 (string property, int index, Int32 defaultValue) |
| Gets the value of the specified property from an array as a signed 32-bit integer. | |
| partial UInt32 | GetComponentUInt32 (string property, int index, UInt32 defaultValue) |
| Gets the value of the specified property from an array as an unsigned 32-bit integer. | |
| partial Int64 | GetComponentInt64 (string property, int index, Int64 defaultValue) |
| Gets the value of the specified property from an array as a signed 64-bit integer. | |
| partial UInt64 | GetComponentUInt64 (string property, int index, UInt64 defaultValue) |
| Gets the value of the specified property from an array as an unsigned 64-bit integer. | |
| partial float | GetComponentFloat32 (string property, int index, float defaultValue) |
| Gets the value of the specified property from an array as a 32-bit floating-point number. | |
| partial double | GetComponentFloat64 (string property, int index, double defaultValue) |
| Gets the value of the specified property property from an array as a 64-bit floating-point number. | |
| partial Boolean | GetComponentBoolean (string property, int index, Boolean defaultValue) |
| Gets the value of the specified property property from an array as a boolean value. | |
| partial String | GetComponentString (string property, int index, String defaultValue) |
| Gets the value of the specified property from an array as a string. | |
| partial int | GetComponentCount (string property) |
| Gets the number of components in the array. | |
| partial MetadataType | GetComponentType (string property) |
| Gets the type of component array. | |
| partial MetadataType | GetMetadataType (string property) |
| Gets the type of the specified property. | |
| partial bool | IsNormalized (string property) |
| Determines if the specified property's value is normalized. | |
Properties | |
| string | className [get, set] |
| The name of the class that this CesiumFeature conforms to. | |
| string | featureTableName [get, set] |
| The name of the feature table containing the values of this CesiumFeature's properties. | |
| string[] | properties [get, set] |
| The names of the properties that exist in this CesiumFeature. | |
Definition at line 33 of file CesiumFeature.cs.
Returns the default value if the property value cannot be converted to that type.
| property | The name of the property. |
| defaultValue | The default value. |
| partial Boolean CesiumForUnity.CesiumFeature.GetComponentBoolean | ( | string | property, |
| int | index, | ||
| Boolean | defaultValue ) |
| index | The index of the component. |
| partial int CesiumForUnity.CesiumFeature.GetComponentCount | ( | string | property | ) |
| partial float CesiumForUnity.CesiumFeature.GetComponentFloat32 | ( | string | property, |
| int | index, | ||
| float | defaultValue ) |
| partial double CesiumForUnity.CesiumFeature.GetComponentFloat64 | ( | string | property, |
| int | index, | ||
| double | defaultValue ) |
| partial Int16 CesiumForUnity.CesiumFeature.GetComponentInt16 | ( | string | property, |
| int | index, | ||
| Int16 | defaultValue ) |
| partial Int32 CesiumForUnity.CesiumFeature.GetComponentInt32 | ( | string | property, |
| int | index, | ||
| Int32 | defaultValue ) |
| partial Int64 CesiumForUnity.CesiumFeature.GetComponentInt64 | ( | string | property, |
| int | index, | ||
| Int64 | defaultValue ) |
| partial sbyte CesiumForUnity.CesiumFeature.GetComponentInt8 | ( | string | property, |
| int | index, | ||
| sbyte | defaultValue ) |
| partial String CesiumForUnity.CesiumFeature.GetComponentString | ( | string | property, |
| int | index, | ||
| String | defaultValue ) |
| partial MetadataType CesiumForUnity.CesiumFeature.GetComponentType | ( | string | property | ) |
| partial UInt16 CesiumForUnity.CesiumFeature.GetComponentUInt16 | ( | string | property, |
| int | index, | ||
| UInt16 | defaultValue ) |
| partial UInt32 CesiumForUnity.CesiumFeature.GetComponentUInt32 | ( | string | property, |
| int | index, | ||
| UInt32 | defaultValue ) |
| partial UInt64 CesiumForUnity.CesiumFeature.GetComponentUInt64 | ( | string | property, |
| int | index, | ||
| UInt64 | defaultValue ) |
| partial byte CesiumForUnity.CesiumFeature.GetComponentUInt8 | ( | string | property, |
| int | index, | ||
| partial float CesiumForUnity.CesiumFeature.GetFloat32 | ( | string | property, |
| partial double CesiumForUnity.CesiumFeature.GetFloat64 | ( | string | property, |
| partial sbyte CesiumForUnity.CesiumFeature.GetInt8 | ( | string | property, |
| partial MetadataType CesiumForUnity.CesiumFeature.GetMetadataType | ( | string | property | ) |
| partial byte CesiumForUnity.CesiumFeature.GetUInt8 | ( | string | property, |
| partial bool CesiumForUnity.CesiumFeature.IsNormalized | ( | string | property | ) |
getset |
Definition at line 38 of file CesiumFeature.cs.
getset |
Definition at line 43 of file CesiumFeature.cs.
getset |
Definition at line 48 of file CesiumFeature.cs.
