Cesium for Unity 1.26.1
CesiumFeature.cs
1using Reinterop;
2using UnityEngine;
3using System;
5namespace CesiumForUnity
6{
27
31 [ReinteropNativeImplementation("CesiumForUnityNative::CesiumFeatureImpl", "CesiumFeatureImpl.h")]
32 [Obsolete("Retrieve feature IDs from the CesiumPrimitiveFeatures component attached to a mesh primitive instead. For metadata, use the CesiumModelMetadata component attached to its parent game object.")]
33 public partial class CesiumFeature
34 {
38 public string className { get; internal set; }
39
43 public string featureTableName { get; internal set; }
44
48 public string[] properties { get; internal set; }
49
56 public partial sbyte GetInt8(string property, sbyte defaultValue);
57
64 public partial byte GetUInt8(string property, byte defaultValue);
65
72 public partial Int16 GetInt16(string property, Int16 defaultValue);
73
80 public partial UInt16 GetUInt16(string property, UInt16 defaultValue);
81
88 public partial Int32 GetInt32(string property, Int32 defaultValue);
89
96 public partial UInt32 GetUInt32(string property, UInt32 defaultValue);
97
104 public partial Int64 GetInt64(string property, Int64 defaultValue);
105
112 public partial UInt64 GetUInt64(string property, UInt64 defaultValue);
113
120 public partial float GetFloat32(string property, float defaultValue);
121
128 public partial double GetFloat64(string property, double defaultValue);
129
136 public partial Boolean GetBoolean(string property, Boolean defaultValue);
137
144 public partial String GetString(string property, String defaultValue);
145
153 public partial sbyte GetComponentInt8(string property, int index, sbyte defaultValue);
154
162 public partial byte GetComponentUInt8(string property, int index, byte defaultValue);
163
171 public partial Int16 GetComponentInt16(string property, int index, Int16 defaultValue);
172
180 public partial UInt16 GetComponentUInt16(string property, int index, UInt16 defaultValue);
181
189 public partial Int32 GetComponentInt32(string property, int index, Int32 defaultValue);
190
198 public partial UInt32 GetComponentUInt32(string property, int index, UInt32 defaultValue);
199
207 public partial Int64 GetComponentInt64(string property, int index, Int64 defaultValue);
208
216 public partial UInt64 GetComponentUInt64(string property, int index, UInt64 defaultValue);
217
225 public partial float GetComponentFloat32(string property, int index, float defaultValue);
226
235 public partial double GetComponentFloat64(string property, int index, double defaultValue);
236
244 public partial Boolean GetComponentBoolean(string property, int index, Boolean defaultValue);
245
253 public partial String GetComponentString(string property, int index, String defaultValue);
254
259 public partial int GetComponentCount(string property);
260
265 public partial MetadataType GetComponentType(string property);
266
271 public partial MetadataType GetMetadataType(string property);
272
277 public partial bool IsNormalized(string property);
278 }
279}
Allows access to a particular feature of CesiumMetadata.
Gets the value of the specified property from an array as a string.
Gets the value of the specified property from an array as a byte.
Gets the type of component array.
Gets the value of the specified property from an array as a signed 32-bit integer.
Gets the value of the specified property as an unsigned 64-bit integer.
Gets the value of the specified property from an array as a signed 16-bit integer.
Gets the value of the specified property as a string.
Gets the value of the specified property from an array as a 32-bit floating-point number.
Gets the value of the specified property property from an array as a boolean value.
string[] properties
The names of the properties that exist in this CesiumFeature.
Gets the value of the specified property from an array as an unsigned 16-bit integer.
Gets the value of the specified property as an unsigned 16-bit integer.
Gets the value of the specified property as a signed byte.
Gets the value of the specified property as a signed 32-bit integer.
Gets the value of the specified property as a boolean value.
Gets the value of the specified property as a byte.
Gets the value of the specified property property from an array as a 64-bit floating-point number.
string className
The name of the class that this CesiumFeature conforms to.
Gets the value of the specified property from an array as an unsigned 64-bit integer.
Gets the value of the specified property as a signed 16-bit integer.
Gets the value of the specified property from an array as a signed byte.
Gets the number of components in the array.
Determines if the specified property's value is normalized.
The name of the feature table containing the values of this CesiumFeature's properties.
Gets the value of the specified property from an array as a signed 64-bit integer.
Gets the value of the specified property from an array as an unsigned 32-bit integer.
Gets the value of the specified property as a 32-bit floating-point number.
Gets the value of the specified property as a signed 64-bit integer.
Gets the type of the specified property.
Gets the value of the specified property as a 64-bit floating-point number.
Gets the value of the specified property as an unsigned 32-bit integer.
MetadataType
Identifies the type of a property.
