Cesium for Unity 1.26.1
CesiumForUnity.CesiumDebugColorizeTilesRasterOverlay Class Reference
A raster overlay that can be used to debug tilesets by shading each tile with a random color. More...
Inheritance diagram for CesiumForUnity.CesiumDebugColorizeTilesRasterOverlay:
Protected Member Functions
Additional Inherited Members
void AddToTileset ()
void RemoveFromTileset ()
void Refresh ()
string materialKey [get, set]
Definition at line 14 of file CesiumDebugColorizeTilesRasterOverlay.cs.
◆ AddToTileset()
override partial void CesiumForUnity.CesiumDebugColorizeTilesRasterOverlay.AddToTileset ( Cesium3DTileset tileset)
protected
◆ RemoveFromTileset()
override partial void CesiumForUnity.CesiumDebugColorizeTilesRasterOverlay.RemoveFromTileset ( Cesium3DTileset tileset)
protected
