Cesium for Unity 1.26.1
CesiumForUnity.CesiumBingMapsRasterOverlay Class Reference
A raster overlay that directly accesses Bing Maps. More...
Inheritance diagram for CesiumForUnity.CesiumBingMapsRasterOverlay:
Protected Member Functions
Properties
string bingMapsKey [get, set]
 The Bing Maps API key to use.
BingMapsStyle mapStyle [get, set]
 The map style to use.
string materialKey [get, set]
Additional Inherited Members
void AddToTileset ()
void RemoveFromTileset ()
void Refresh ()
If you're using Bing Maps via Cesium ion, use the CesiumIonRasterOverlay component instead.
Definition at line 32 of file CesiumBingMapsRasterOverlay.cs.
◆ AddToTileset()
override partial void CesiumForUnity.CesiumBingMapsRasterOverlay.AddToTileset ( Cesium3DTileset tileset)
protected
◆ RemoveFromTileset()
override partial void CesiumForUnity.CesiumBingMapsRasterOverlay.RemoveFromTileset ( Cesium3DTileset tileset)
protected
Property Documentation
◆ bingMapsKey
string CesiumForUnity.CesiumBingMapsRasterOverlay.bingMapsKey
getset
Definition at line 40 of file CesiumBingMapsRasterOverlay.cs.
◆ mapStyle
BingMapsStyle CesiumForUnity.CesiumBingMapsRasterOverlay.mapStyle
getset
Definition at line 56 of file CesiumBingMapsRasterOverlay.cs.
